  • 24 Vote(s) - 2.83 Average
sd connect problem
Hello!
Can somebody help me? I have c4 chinese clone which was worked well 09/2015 xentry. Last week i installed 09/2016 xentry to another hard disk. I tried to configure mux to connect with the computer but i couldnt it didn't connect even with the green cable. Cant run self diagnose or update and screen on the mux is different of the usual. Then i put older version of xentry back and have the same problem. I attached pictures. Thanks for helping me
Thanks given by: obdshop
Put batteries in it and try to run the update.
For Sale:
CDA 6 Installation, FCA Flash File Downloader, JSON Error Fix
Nissan IP Characteristics CVT Transmission CSV File Service
Module Cloning Services - USA Only
Honda i-HDS diagnostic software
Thanks given by: omega1
(11-11-2016, 01:02 AM)hasoon2000 Wrote: Put batteries in it and try to run the update.
I have already tried it but didn't work
Looks like we have a syndrome here...let's call it "2016 bricked C4".
Are you using a native install or a VMware image?
Seems like something is going completely wrong with chinese muxes using recent releases from Miss Daimler.
Could be some subtle changes made by MB to brick muxes or who knows what's behind this.
Refrain to update anything and better stop using recent versions because something is really fishy with them.
Based on the other thread running these days your mux can be bricked already or try with another older version to see if the same (different than 09.2015 which you are trying to use now).
Did a little research. Based on your error message, it's a common issue.
http://mhhauto.com/Thread-DCDI-eErrorCode-204-204-error
Someone has a thread in Selling Box to fix it.
http://mhhauto.com/Thread-Sd-Connect-rep...de-204-204
For Sale:
I help you, contact my Skype grajek41
Thanks given by: omega1 , Marcos
