sd connect problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: sd connect problem (/Thread-sd-connect-problem--112778) |
sd connect problem - omega1 - 11-11-2016 Hello! Can somebody help me? I have c4 chinese clone which was worked well 09/2015 xentry. Last week i installed 09/2016 xentry to another hard disk. I tried to configure mux to connect with the computer but i couldnt it didn't connect even with the green cable. Cant run self diagnose or update and screen on the mux is different of the usual. Then i put older version of xentry back and have the same problem. I attached pictures. Thanks for helping me RE: sd connect problem - hasoon2000 - 11-11-2016 Put batteries in it and try to run the update. RE: sd connect problem - omega1 - 11-11-2016 (11-11-2016, 01:02 AM)hasoon2000 Wrote: Put batteries in it and try to run the update.I have already tried it but didn't work RE: sd connect problem - Marcos - 11-11-2016 Looks like we have a syndrome here...let's call it "2016 bricked C4". Are you using a native install or a VMware image? Seems like something is going completely wrong with chinese muxes using recent releases from Miss Daimler. Could be some subtle changes made by MB to brick muxes or who knows what's behind this. Refrain to update anything and better stop using recent versions because something is really fishy with them. Based on the other thread running these days your mux can be bricked already or try with another older version to see if the same (different than 09.2015 which you are trying to use now). RE: sd connect problem - hasoon2000 - 11-11-2016 Did a little research. Based on your error message, it's a common issue. http://mhhauto.com/Thread-DCDI-eErrorCode-204-204-error Someone has a thread in Selling Box to fix it. http://mhhauto.com/Thread-Sd-Connect-repair-f-ex-DCDI-eErrorCode-204-204 RE: sd connect problem - siroce - 11-12-2016 I help you, contact my Skype grajek41 |
