  • 3 Vote(s) - 2.33 Average
sensotronic brake faulty
i had problem with the sensotronic brake system gives a fault pressure reservoir faulty the esp system ok the warning braking reduced always on the car as i think around 2007 any help please
Change hydraulic unit
Thanks given by: william87
If its reservoir only, you can change only that (no need change whole unit)
Most cases I had I changed whole unit cause by changing reservoir never helped
