  • 10 Vote(s) - 3.1 Average
smart two two
hello i have here a smart two two from 2002 it has a gear problem sometimes gives 3 stripes but some times it gives n when it gives n i can start the starter is turning but the car dont goes on.
does any one know if it could be the gearing that cosses the starting problem
If this is the same one as fitted in the mitsubishi colt they have a bad clutch actuator made by sachs and it sticks. The colt certainly uses a smart semi box
Thanks given by: Bogdan Beb
So,
Check you engine earth, the clutch actuator, 3rd brake light, brake light switch, and the wiring harness going to the gearbox.
Thanks given by: laz79
My first suspicion would be a chaffed clutch actuator wiring, it can rub and wear through on the intercooler scoop.
Yes, 3 stripes on dash, always problem with clutch or brake lights or brake light switch. Nanant is 100% right. Take a look to the actuator. Remove the actuator and take a look to the hole. You can see the clutch bearing lever. Sometimes there is a problem with rusty lever.
Thanks given by: nanant
yes, check all of the above. There are 4 plugs and sockets from the loom to the gearbox. As far as I remember 3 lines is a communication/actuation problem. I had this after an engine rebuild and one of the plugs was not quite connected properly.
when re-connected issue was fixed.
