smart two two - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: smart two two (/Thread-smart-two-two) |
smart two two - gordonasp - 11-04-2016 hello i have here a smart two two from 2002 it has a gear problem sometimes gives 3 stripes but some times it gives n when it gives n i can start the starter is turning but the car dont goes on. does any one know if it could be the gearing that cosses the starting problem RE: smart two two - laz79 - 11-04-2016 If this is the same one as fitted in the mitsubishi colt they have a bad clutch actuator made by sachs and it sticks. The colt certainly uses a smart semi box RE: smart two two - nanant - 11-04-2016 So, Check you engine earth, the clutch actuator, 3rd brake light, brake light switch, and the wiring harness going to the gearbox. RE: smart two two - Indigo - 11-06-2016 My first suspicion would be a chaffed clutch actuator wiring, it can rub and wear through on the intercooler scoop. RE: smart two two - Jan1980 - 11-06-2016 Yes, 3 stripes on dash, always problem with clutch or brake lights or brake light switch. Nanant is 100% right. Take a look to the actuator. Remove the actuator and take a look to the hole. You can see the clutch bearing lever. Sometimes there is a problem with rusty lever. RE: smart two two - technonut - 11-13-2016 yes, check all of the above. There are 4 plugs and sockets from the loom to the gearbox. As far as I remember 3 lines is a communication/actuation problem. I had this after an engine rebuild and one of the plugs was not quite connected properly. when re-connected issue was fixed. |
