  • 16 Vote(s) - 3.44 Average
[solved]xentry openshell 2016.09version das error
Hi..
I installed twice openshell 2016.09 version.
And I tested. xentry w204 good working.. But das 220 isn't connection.
I done patch(C4 Blacklist Patch as DieTRih)
What is the problem...? Fault (1.2)-2.503.13011.
please.. Help me....
Thanks given by: dog_seb
Try start car and test it again or little "protocol upgrade" can be loaded to SDConnect during this step. It was done? DieTRih´s patch is ok as usually.
Thanks given by: smlee747
Did you change your ip adress? Go to LAN and change ip to 172.29.127.222
(09-18-2016, 01:56 PM)boonyen Wrote: Did you change your ip adress? Go to LAN and change ip to 172.29.127.222
Do you think it would work with a W204 and Xentry if the IP address was incorrect?
What if he is using WLAN and not LAN at all?
Thanks given by: daxxer , Rocinante , laco210
Try to reinstall the new operating system and Xentry from scratch
use genuine das “bin” folder,only replace file lic.sli
...did you change the date to 2016.09 ? everyhting can happen in xentry/das...and the date its most important.
cheers...
das/bin / gbf file
exchange
new gfb file das/bin
https:dontpostdirectlinksinthreads!!! please read the rules. Use a .txt file
//edit by R
http://mhhauto.com/Thread-Xentry-WIS-Sta...ge-Torrent
