[solved]xentry openshell 2016.09version das error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: [solved]xentry openshell 2016.09version das error (/Thread-solved-xentry-openshell-2016-09version-das-error) Pages:
[solved]xentry openshell 2016.09version das error - smlee747 - 09-18-2016 Hi.. I installed twice openshell 2016.09 version. And I tested. xentry w204 good working.. But das 220 isn't connection. I done patch(C4 Blacklist Patch as DieTRih) What is the problem...? Fault (1.2)-2.503.13011. please.. Help me.... RE: xentry openshell 2016.09version das error - laco210 - 09-18-2016 Try start car and test it again or little "protocol upgrade" can be loaded to SDConnect during this step. It was done? DieTRih´s patch is ok as usually. RE: xentry openshell 2016.09version das error - boonyen - 09-18-2016 Did you change your ip adress? Go to LAN and change ip to 172.29.127.222 RE: xentry openshell 2016.09version das error - DBmhh - 09-18-2016 (09-18-2016, 01:56 PM)boonyen Wrote: Did you change your ip adress? Go to LAN and change ip to 172.29.127.222 Do you think it would work with a W204 and Xentry if the IP address was incorrect? What if he is using WLAN and not LAN at all? RE: xentry openshell 2016.09version das error - alex09 - 09-18-2016 Try to reinstall the new operating system and Xentry from scratch RE: xentry openshell 2016.09version das error - must - 09-18-2016 use genuine das “bin” folder,only replace file lic.sli RE: [solved]xentry openshell 2016.09version das error - mustang - 11-03-2016 ...did you change the date to 2016.09 ? everyhting can happen in xentry/das...and the date its most important. cheers... RE: [solved]xentry openshell 2016.09version das error - szumilaci - 11-03-2016 das/bin / gbf file exchange new gfb file das/bin https:dontpostdirectlinksinthreads!!! please read the rules. Use a .txt file //edit by R RE: [solved]xentry openshell 2016.09version das error - szumilaci - 11-04-2016 http://mhhauto.com/Thread-Xentry-WIS-StarFinder-09-2016-Win7-x64-Acronis-Image-Torrent |
