  • 16 Vote(s) - 3 Average
w176 no start no fault codes
I have a Mercedes w176 and it is a pain in the ass. The car came with a platform because it would not start. I run a quick test and all control units were clear. i tried to start the car but the engine would half turn and stop. Something was cutting it off electrically. Furthermore, with out any obvious reason, the engine fan started working and the communication with the engine was lost. i have discovered that the the engine control was loosing a ground point. that is why the engine fan started. i have put an outside earth and the car came back in engine turning and cutting out electrically. I have tried everything.
checked all fuses and relays (including the mini relays)
replaced terminal 30g relay
replaced exhaust camshaft sensor
checked crank sensor with oscilloscope and looks ok
tried second key
guided test for drive authorization (all ok)
and many many more
still no fault codes.
any ideas are welcome. thank you
can u trigger a dtc code by disconnecting engine sensors? Is it a diesel car?
No it is a gasoline with 270 engine year 2013. i have plugged a lot plugs out like camshaft sensor and i didn't get any faults. now i have out the intake air pressure sensor plug and i have a fault. it is very strange
The problem with most technically inclined individuals trying to fix a dead engine is that we tend to quickly forget ''THE BASICS'' ingredients for combustion to take place just so the engine may run!
1. Check for spark, is it there throughout or intermittently or not there at all,
-Famous L5, ECU, DI coils, e.t.c
2. Check for fuel rail pressure ( challenging on any A-class but doable if u want it to start and run),
furthermore M270 has piezo direct injection. so u have to find a way to confirm that fuel is delivered (repair fuel system accordingly)
3. Check for compression and make reference to specific values in WIS.
“We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
Thanks given by: Mercerwin
sparks,fuel and fuel injectors are ok. if something like this was faulty why the engine does not turn and just not start. in my case after half cycle the engine stops turning electronically. something is cutting it down.
looks like problem is with power supply, but you said you checked everything accroding.. Can you perform software update for engine cu?
Mercedes Comand/Audio antitheft codes all NTG
Mercedes NTG5-6 Regio Software
the engine ecu is up to date.i have checked online. i believe that someting is shorted inside the engine ecu.
it doesnt looks like high exhaust back pressure, right?
You can try supply ecu with another battery or if you have similar car swap engine cu, ezs and key.
if i replace the engine ecu,ezs and key, it will not also need the gearbox electric plate in order to start? so this is not a case. a faulty exhaust back pressure sensor can cause the engine ot to be able to turn? also, i have found the starter relay, kept it press, the engine turns normally but it would still not start!
