w176 no start no fault codes - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: w176 no start no fault codes (/Thread-w176-no-start-no-fault-codes) Pages:
w176 no start no fault codes - pambossavva89 - 02-16-2017 Hello, I have a Mercedes w176 and it is a pain in the ass. The car came with a platform because it would not start. I run a quick test and all control units were clear. i tried to start the car but the engine would half turn and stop. Something was cutting it off electrically. Furthermore, with out any obvious reason, the engine fan started working and the communication with the engine was lost. i have discovered that the the engine control was loosing a ground point. that is why the engine fan started. i have put an outside earth and the car came back in engine turning and cutting out electrically. I have tried everything. checked all fuses and relays (including the mini relays) replaced terminal 30g relay replaced exhaust camshaft sensor checked crank sensor with oscilloscope and looks ok tried second key guided test for drive authorization (all ok) and many many more still no fault codes. any ideas are welcome. thank you RE: w176 no start no fault codes - ruklis - 02-16-2017 can u trigger a dtc code by disconnecting engine sensors? Is it a diesel car? RE: w176 no start no fault codes - pambossavva89 - 02-16-2017 No it is a gasoline with 270 engine year 2013. i have plugged a lot plugs out like camshaft sensor and i didn't get any faults. now i have out the intake air pressure sensor plug and i have a fault. it is very strange RE: w176 no start no fault codes - Dollsburg - 02-16-2017 The problem with most technically inclined individuals trying to fix a dead engine is that we tend to quickly forget ''THE BASICS'' ingredients for combustion to take place just so the engine may run! 1. Check for spark, is it there throughout or intermittently or not there at all, -Famous L5, ECU, DI coils, e.t.c 2. Check for fuel rail pressure ( challenging on any A-class but doable if u want it to start and run), furthermore M270 has piezo direct injection. so u have to find a way to confirm that fuel is delivered (repair fuel system accordingly) 3. Check for compression and make reference to specific values in WIS. RE: w176 no start no fault codes - pambossavva89 - 02-16-2017 sparks,fuel and fuel injectors are ok. if something like this was faulty why the engine does not turn and just not start. in my case after half cycle the engine stops turning electronically. something is cutting it down. RE: w176 no start no fault codes - A2ua - 02-16-2017 looks like problem is with power supply, but you said you checked everything accroding.. Can you perform software update for engine cu? RE: w176 no start no fault codes - pambossavva89 - 02-16-2017 the engine ecu is up to date.i have checked online. i believe that someting is shorted inside the engine ecu. RE: w176 no start no fault codes - A2ua - 02-16-2017 it doesnt looks like high exhaust back pressure, right? You can try supply ecu with another battery or if you have similar car swap engine cu, ezs and key. RE: w176 no start no fault codes - pambossavva89 - 02-16-2017 if i replace the engine ecu,ezs and key, it will not also need the gearbox electric plate in order to start? so this is not a case. a faulty exhaust back pressure sensor can cause the engine ot to be able to turn? also, i have found the starter relay, kept it press, the engine turns normally but it would still not start! |
