  • 14 Vote(s) - 3.07 Average
w202 wont rev
Have a w202 with 2.8 I6. Came in running very badly, fuel trim and misfire codes. Did spark plugs, coils, wires, fixed many vacuum leaks. Then it idled very smooth, no codes. If you hit the throttle the car would sputter and cut ignition, watching ignition tester. Changed throttle body, no difference. About to check timing tomorrow, but any ideas?
Again, no codes.
Thanks.
How is the engine harness? Air mass sensor?
Thanks given by: bawarek , EASatlanta , craig coopen
(12-10-2016, 08:40 AM)Rocinante Wrote: How is the engine harness? Air mass sensor?
Cant find any broken spots in harness.... I specifically took apart harness that wraps around rear or motor, no breaks, insulation not even brittle.
MAF reading perfectly, but unplugged still nothing. Pulling covers right now to tcheck timing.
Sounds like a bad MAF sensor to me. I have seen them cause misfires, lack of power and other strange problems. It would be worth a try to substitute a known good part just to see.
Maybe plugged cat? Disconnect the exhaust at the manifold & try it.
Thanks given by: Rocinante
Timing was good.
Ended up being crankshaft pos. sensor was hitting the flywheel, bracket was bent.
Replaced sensor, put washers on bracket. All good.
Thanks given by: KriyenKPp , Rocinante
