w202 wont rev - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: w202 wont rev (/Thread-w202-wont-rev) |
w202 wont rev - EASatlanta - 12-10-2016 Have a w202 with 2.8 I6. Came in running very badly, fuel trim and misfire codes. Did spark plugs, coils, wires, fixed many vacuum leaks. Then it idled very smooth, no codes. If you hit the throttle the car would sputter and cut ignition, watching ignition tester. Changed throttle body, no difference. About to check timing tomorrow, but any ideas? Again, no codes. Thanks. RE: w202 wont rev - Rocinante - 12-10-2016 How is the engine harness? Air mass sensor? RE: w202 wont rev - EASatlanta - 12-10-2016 (12-10-2016, 08:40 AM)Rocinante Wrote: How is the engine harness? Air mass sensor? Cant find any broken spots in harness.... I specifically took apart harness that wraps around rear or motor, no breaks, insulation not even brittle. MAF reading perfectly, but unplugged still nothing. Pulling covers right now to tcheck timing. RE: w202 wont rev - RPM55 - 12-10-2016 Sounds like a bad MAF sensor to me. I have seen them cause misfires, lack of power and other strange problems. It would be worth a try to substitute a known good part just to see. RE: w202 wont rev - mbtuner - 12-12-2016 Maybe plugged cat? Disconnect the exhaust at the manifold & try it. RE: w202 wont rev - EASatlanta - 12-16-2016 Timing was good. Ended up being crankshaft pos. sensor was hitting the flywheel, bracket was bent. Replaced sensor, put washers on bracket. All good. |
