[solved]xentry openshell 2016.09version das error - Printable Version
+---- Thread: [solved]xentry openshell 2016.09version das error (/Thread-solved-xentry-openshell-2016-09version-das-error)
RE: [solved]xentry openshell 2016.09version das error - aslamaslam - 12-11-2016
(09-18-2016, 11:27 AM)smlee747 Wrote: Hi..
I installed twice openshell 2016.09 version.
And I tested. xentry w204 good working.. But das 220 isn't connection.
I done patch(C4 Blacklist Patch as DieTRih)
What is the problem...? Fault (1.2)-2.503.13011.
please.. Help me....
hello i have same problem
RE: [solved]xentry openshell 2016.09version das error - Rocinante - 12-11-2016
Well if you read the whole thread, which is only 9 post more than yours, you would have found the solution..
RE: [solved]xentry openshell 2016.09version das error - smlee747 - 12-11-2016
(12-11-2016, 01:59 AM)Rocinante Wrote: Well if you read the whole thread, which is only 9 post more than yours, you would have found the solution..
Hi
My install is problem...
openshell 201609 version install and Java install ... Good working..
Java install and openshell 201609 version install ... Fault (1.2)-2.503.13011
Good luck..
RE: [solved]xentry openshell 2016.09version das error - Rocinante - 12-12-2016
I'm not understanding.. so if you install Java first, before Open Shell, then you get an error?
If so, then just install Open Shell first.. I always recommend a fresh format and Windows install with each new release. It guarantees there is nothing left over to interfere with the operation of Open Shell..
RE: [solved]xentry openshell 2016.09version das error - HestonDiag - 12-12-2016
I had a strange experience. I had a working 5.2016 install, but after playing around with it I got the 13011 error as well.
Tried copying the GBF folder and had no luck, also tried copying the entire DAS folder from a working 5.2016 install and still had the error. Still working fine with Xentry, just DAS has this error.
My suspicion is that a patch made this error, but as I am not certain of this I do not want to name any names without proof. All I will say is I don't think the patch that made this error was from Mr. DieTRih - from my experience, patches from Mr. DieTRih are 101% perfect.
I suggest same as Mr. Rocinante - time for fresh install using fresh copy of windows, and use Mr. DieTRih's patches instead of any others you may find.
