VVDI MB can't connect to ECU - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: VVDI MB can't connect to ECU (/Thread-VVDI-MB-can-t-connect-to-ECU) Pages:
RE: VVDI MB can't connect to ECU - tkinyan - 09-26-2016 I connected the cables from VVDI MB tools OBD to ECU directly. Every function is fine. If you using ECU adapter cable, please check did the can high and can low of the plug is short circuit. Some times there will have short circuit on the serial port of the ECU adapter RE: VVDI MB can't connect to ECU - BigK - 09-26-2016 I tried to go directly, and it is still the same. I added 2 120ohm resistors, in series, for CAN L, and CAN H, or do I bridge them?(parallel) I have tried every combination. RE: VVDI MB can't connect to ECU - daxxer - 09-26-2016 (09-26-2016, 10:27 PM)BigK Wrote: I tried to go directly, and it is still the same. no need any resistors in series, when you don't understand basic knowlege about direct CAN connection to alone ECU without car only on bench, then forget to get any results... ![]() RE: VVDI MB can't connect to ECU - BigK - 09-26-2016 (09-26-2016, 10:35 PM)daxxer Wrote:(09-26-2016, 10:27 PM)BigK Wrote: I tried to go directly, and it is still the same. I know it's part of the game, but sorry for my frustration for trying to fix a brand new product I just purchased. I read Line Theory, and realize two terminating resistors is best. But regardless, if there was an quality control, I probably wouldn't be posting and wasting time. RE: VVDI MB can't connect to ECU - daxxer - 09-26-2016 (09-26-2016, 11:04 PM)BigK Wrote: I know it's part of the game, but sorry for my frustration for trying to fix a brand new product I just purchased. I read Line Theory, and realize two terminating resistors is best. But regardless, if there was an quality control, I probably wouldn't be posting and wasting time. yes, i understand you...when you want to have sure about your VVDI unit, then try to read some other ECU, no need renew it, only try to read it... ![]() about the resistor 120 ohm value for using by CAN lines, its a basic knowlege, why and where must be this resistor used as "end terminator" for success data reading...
RE: VVDI MB can't connect to ECU - webmaster - 09-28-2016 Just make direct connection from OBD2 to ECU and give power supply. In my case I'm not using resistance ![]() OBD2 side: http://pinoutsguide.com/CarElectronics/mercedes_obd2_diag_pinout.shtml ECU Side: 2: Ground 15 & 16: 12 Volts 41: CAN High 54: CAN Low Best regards. RE: VVDI MB can't connect to ECU - BigK - 10-04-2016 (09-28-2016, 01:38 AM)webmaster Wrote: Just make direct connection from OBD2 to ECU and give power supply. I have tried this as well, with several ECUs now with no luck. I am not sure if it's a faulty VVDI, or something trivial I am not noticing RE: VVDI MB can't connect to ECU - daxxer - 10-04-2016 (09-22-2016, 11:32 PM)IGNASIO88 Wrote: ME97 connected to - data read from ECU, did not try to reset. Check the scheme of connection. right ![]() BigK: check the wiring, sure must be somewehre some miniatur fault... ![]() (09-28-2016, 01:38 AM)webmaster Wrote: Just make direct connection from OBD2 to ECU and give power supply.
