722.6 issue - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: 722.6 issue (/Thread-722-6-issue) |
722.6 issue - JanS211 - 10-25-2016 Check the wiring harness for oil contamination. The bushing where the connector is plugged in the transmission often fails and oil can be pushed into the transmission ECU. Gesendet von iPhone mit Tapatalk RE: 722.6 issue - efka - 10-25-2016 I would not dig in transmission itself..... sounds like wrong load signal...... AIR FLOW METER RE: 722.6 issue - salerka - 10-25-2016 i agree efka. Because after acceleration on P car and transmission works correctly. RE: 722.6 issue - KG7222 - 10-25-2016 (10-25-2016, 12:30 AM)efka Wrote: I would not dig in transmission itself..... sounds like wrong load signal...... AIR FLOW METER Its interesting. I have new air flow and will test it. But one friend have the same problem...with the same rpm changes... RE: 722.6 issue - kin1830 - 10-25-2016 one time i found a broken spring in the valve body , i know it was delay shifting but cannot remember which gear RE: 722.6 issue - efka - 10-25-2016 (10-25-2016, 12:42 AM)mbsupport Wrote:(10-25-2016, 12:30 AM)efka Wrote: I would not dig in transmission itself..... sounds like wrong load signal...... AIR FLOW METER do not forget to clear adaptation values in engine computer RE: 722.6 issue - David Sun - 10-26-2016 Open the ECU, check ECU internal connector, has been broken RE: 722.6 issue - Jeff_Spicoli - 11-02-2016 Program the tranny with the lastest calibration before taking anything apart. RE: 722.6 issue - thushi91 - 11-02-2016 not problem with the transmission itself, check boost pressure sensors, MAF, turbo air lines leakages |
