C4 HHTWIN Will not launch! - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: C4 HHTWIN Will not launch! (/Thread-C4-HHTWIN-Will-not-launch) Pages:
RE: C4 HHTWIN Will not launch! - iRik - 12-13-2016 (12-13-2016, 03:14 AM)EASatlanta Wrote: Mine is different.... I click the hhtpkw file, it does the same thing. I allready run Xentry.OpenShell.HHT from DieTRih and how can I point DAS to hhtwin directory? RE: C4 HHTWIN Will not launch! - maxbg - 12-13-2016 Technically to point Das to HHT Dir you just need Star diagnose compact4 reg key and add hht path to system path variable but if you use solution from master DieTRih it will be done automatically and if doesn't work it is some sort of glitch in the system. I also had it once before but after reinstalling OS works fine again. Try to install clean windows then XDOS (don't use "patcher") and install HHT. |
