SD Connect MUX Voltage & Amperage through OBDII Port - Printable Version
+---- Thread: SD Connect MUX Voltage & Amperage through OBDII Port (/Thread-SD-Connect-MUX-Voltage-Amperage-through-OBDII-Port)
RE: SD Connect MUX Voltage & Amperage through OBDII Port - Rennbenz - 01-06-2017
Hey,
I always connect the charger directly to the cable. Remember to remove the insulation at the plugs ...Kolo
RE: SD Connect MUX Voltage & Amperage through OBDII Port - MD20 - 01-06-2017
Thanks! Yeah sure, wouldn't make sense otherwhise x)
One more thing, is more then 2A bad for the MUX? I have a Laptop charger here that I dont use and the Output is 19V and 4,74A
RE: SD Connect MUX Voltage & Amperage through OBDII Port - DBmhh - 01-06-2017
(01-06-2017, 09:23 PM)MD20 Wrote: Because as far as I know kl15 in the car is 5v (or am I wrong?)
Not really essential at this thread but KL15 is not 5V but 12 or 24 just like KL30. It is just switched (via ignition) instead of permanent plus.
For your SDconnect you only need the KL30 and ground to power it up and to charge batteries.
(01-06-2017, 08:02 PM)MD20 Wrote: I recently bought a SD Connect Clone of china (it has C5 Design with C4 PCB I think). Anyways, I want to use it with the batteries because I want to use it via WiFi.
Another ambiguity, you do not need SDconnect batteries at all for WIFI connectivity. You can use the tool for most tasks even if batteries were not installed.
You need batteries when programming the mux but that needs to be done with the green cable anyway, not via WIFI. Some diagnosis tasks are better done with batteries inserted, but not many.
