Opel Antara DCM3.7AP swap problem(solved) - Printable Version
+---- Forum: GM Group Opel-Vauxhall, Saab, Chevrolet, GM USA, Chrysler Discussions. (https://mhhauto.com/Forum-GM-Group-Opel-Vauxhall-Saab-Chevrolet-GM-USA-Chrysler-Discussions)
+---- Thread: Opel Antara DCM3.7AP swap problem(solved) (/Thread-Opel-Antara-DCM3-7AP-swap-problem-solved)
RE: Opel Antara DCM3.7AP swap problem(solved) - tmrexh - 04-19-2026
i got a problem on a opel antara with dcm3.7ap i read it with xhorse multiprog, the internal flash got corupted and populated all the immo data with ff. now ecu doesnt show up in can network. After i tried with ktag do reflash the using a diferent eprom area using a file from ecu backup hoping to get at least the ecu back online. i modified the vin manualy in the eprom area of the internal flash too but for no use the can network its partialy active when i conected in bench with multiprog it conects using can high/low, power and ground and it reads the the flash but still for whatever reason once conected on the car it doesnt show up. i heard u have a solution can u help me ? Thanks
RE: Opel Antara DCM3.7AP swap problem(solved) - albert2k6 - 07-07-2026
(04-19-2026, 12:55 AM)tmrexh Wrote: i got a problem on a opel antara with dcm3.7ap i read it with xhorse multiprog, the internal flash got corupted and populated all the immo data with ff. now ecu doesnt show up in can network. After i tried with ktag do reflash the using a diferent eprom area using a file from ecu backup hoping to get at least the ecu back online. i modified the vin manualy in the eprom area of the internal flash too but for no use the can network its partialy active when i conected in bench with multiprog it conects using can high/low, power and ground and it reads the the flash but still for whatever reason once conected on the car it doesnt show up. i heard u have a solution can u help me ? Thanks
It’s the same as me.
I need an EEPROM editing programme for the VIN, immobiliser and fuel injectors or other
I can't see the launch diagnosis Sad
best regards
