W211 E220 need battery drain fix? - Printable Version
+---- Thread: W211 E220 need battery drain fix? (/Thread-W211-E220-need-battery-drain-fix)
Pages: 1 2 3 4
RE: W211 E220 need battery drain fix? - Laegaard - 10-24-2016
The draw stays on - all doors are locked , everything is off. Even if left overnight same draw value
RE: W211 E220 need battery drain fix? - Raints - 10-24-2016
then you should mesure on fuses voltage drop.
There you can see exactly which modules are a live.
RE: W211 E220 need battery drain fix? - MorseHan - 10-24-2016
You have a bad battery !
Measure battery voltage, disconnect battery negative terminal over night.
Next day, measure battery voltage again.
You are sure, trunk light isn't on when lid is closed ?
Battery is checked and okay. Full charge over night keeps voltage. Tested with battery tester also good. Yes i only get big amp draws when i connect back front sam. Dont know if interior light is connected to front sam. I badly need info on front sam
RE: W211 E220 need battery drain fix? - autofault - 10-24-2016
Sam units are bad Ive done about 6 in the last 2 months for different faults
I have had a E class with the same problem and it was the battery. poor quaity when the voltage drops so much the modules start waking up and freaking out, the correct bosch battery fixed that one
Put all your fuses back in the right places and start again from the battery and work your way back. make sure you leave it until is shuts down fully, sorry I dont know the usual time frame here an A4 last week took minuets to shut down but then some l322 take 15-20mins
Scott
RE: W211 E220 need battery drain fix? - Rocinante - 10-25-2016
Have you looked in the Central Gateway to check for corrosion?
RE: W211 E220 need battery drain fix? - Laegaard - 10-25-2016
UPDATE!
Here's how i fixed my battery drain problem.
Have to mention that there is still a problem with left front door module, eating 100-120 mA all time. The modules either need replacing or a fix - dunno if its possible yet.
My car is a former taxi, and autodata only provides information on i guess a normal consumer level.
So what i ended up doing was i printed all fuse data from autodata, and then removed the ones that were installed in sam units (front&rear) that wasn't explained or used in datasheet.
I also noticed when dismantling front sam unit that there was oily residue on top cover. I took apart the unit and washed it COMPLETY down with alcohol, then cleaned it with air and assembled it.
I was having 600 mA draw only from front sam unit when car was asleep. So thats where i decided to give it a proper cleaning.
All in all, i have removed up to 10 different fuses from car, not all of them were drawing amps, but since i cannot find any info, and car doesn't show DTC's i don't care.
PROCEDURE:
I removed all fuses, all modules. And then with battery charger on battery, and multimeter on neg battery terminal and other plug on neg battery lead.
Then i started mounting one fuse at time.
So for now, i need door module fixed and maybe offer a brand new battery just to be completely sure.
I sure hope this thread helps other people, as it has taking me quite a long time to find the faults causing this issue. And i dunno if it really helped cleaning sam unit or it just was because i removed every single fuse, ohm'ed it out and placed it back in.
Take care.
Btw thanks to everyone in here who gave me clues to search and helped me diagnosting the car.
Another UPDATE:
To sum up, i assembled the car in every corner that has been apart.
After removing some fuses i am now not able to talk to some of the cars modules. I will try fit a couple more fuses and hopefully the amp draw isn't increasing.
Anyway i get "taxi electrics defective - visit workshop" i'd like to get that message removed, does anyone know a fix?
List of fuses that i have removed:
FASCIA:
F33 (Left front door module)
SPARE WHEEL WELL:
F83 - autodataSadgovernment vehicles) - dunno what that means? anyone?
ENGINE BAY AREA:
F50 (telematics)
F51 autodata: no data only -
F55 (telematics)
F58 (engine management petrol v6/v8)
F60 autodata: no data only -
That's it - can anybody tell me whats up with all those "telematics" fuses and why is there no data on some of the fuses? it definitly has a circuit when opening the sam unit.
RE: W211 E220 need battery drain fix? - Jan1980 - 10-25-2016
Nearly 1.2 Ampere is always a Can-Bus problem. Can Bus does not go sleep. Very very often a problem with seat control module, like anybody said. You have to disconnect the modules one after one and you have to wait for 5 minutes, if it goes sleep..
