W211 E220 need battery drain fix? - Printable Version
+---- Thread: W211 E220 need battery drain fix? (/Thread-W211-E220-need-battery-drain-fix)
Pages: 1 2 3 4
RE: W211 E220 need battery drain fix? - marcobh5 - 10-25-2016
(10-25-2016, 06:08 AM)Jan1980 Wrote: Nearly 1.2 Ampere is always a Can-Bus problem. Can Bus does not go sleep. Very very often a problem with seat control module, like anybody said. You have to disconnect the modules one after one and you have to wait for 5 minutes, if it goes sleep..
Exactly. Do you chech if go sleep can bus?
RE: W211 E220 need battery drain fix? - Laegaard - 10-25-2016
No i haven't. Where should i look? I only have delphi ds150 at this moment.
RE: W211 E220 need battery drain fix? - autofault - 10-25-2016
Scope the CAN wire and see if data is broadcast then wait for it to stop, CAN voltage will drop to a volt or lower when it's shutdown
Scott
Since disconnecting door module and F83 there has been no problem with the car.
It turns over no problem. But i do get "taxi electrics defective - visit workshop" turns out that F83 is for government vehicles which also includes taxi. its a control module that is always powered ON (terminal 30) it will only go to sleep if certain things are met. Apparently my car does not meet any because the taxi company just ripped apart their equipment. Great work!
INFO ON F83 (spare wheel weel)
SVMCU = Special Vehicle Multifunction Control Module
System states
The special vehicle multifunction control unit (SVMCU [MSS]) (N26/9) switches from active mode into the sleep mode if the following conditions have
been fulfilled (if equipped):
CAN interior sleeps
No alarm triggered
Circuit 15 and circuit 15R off
Circuit 58d is zero
Roof sign lamp (E14/4) switched off
Short circuit not detected
Taximeter control unit (A67n1) signals occupied or OFF
Line to alarm button not faulty
-------------------------------------- (think my issue is somewhere between -lines-)
Before each transition into the sleep mode the supply outputs active at circuit 30 ON are subjected to a load assessment.
A check is made as to whether the output can be switched off before the special vehicle multifunction control unit (SVMCU [MSS]) (N26/9) changes
into the sleep mode.
RE: W211 E220 need battery drain fix? - Rocinante - 10-26-2016
Turn off SVMFCM in Central Gateway
RE: W211 E220 need battery drain fix? - Laegaard - 10-26-2016
How? I don't have sd c4. I only have delphi ds150.
What do i need to fix the problem?
I ended up pulling the fuse as earlier mentioned now resulting in fault text and front left door module seems to work fine again. All good 18-20 mA draw. Battery drain is no longer an issue
RE: W211 E220 need battery drain fix? - Aksel S - 10-28-2016
(10-26-2016, 02:14 AM)Laegaard Wrote: How? I don't have sd c4. I only have delphi ds150.
So which fuses have you removed now?
Have you tried removing the MMS module (Taxi modul)? This is not needed for you car but the taxi companys dont remove them. This module does not run on a fuse, this has direct current from the battery. I have had one w211 with this problem it took me ages to figure this out. It was defective and kept every component in the whole car active but no can errors or nothing. It is in the boot in the righthand side...
You can just leave it unplugged, but you need a mercedes tester to program the ZGW and the Cluster. Or else you will get the Taxi defective error...
Hope it helps you out...
Regards
Aksel S, Denmark
