bga key on w210 - Printable Version
+---- Thread: bga key on w210 (/Thread-bga-key-on-w210)
Pages: 1 2 3 4 5
RE: bga key on w210 - mikeburnet - 12-30-2016
i also have give up yes.
i stick with nec keys also.
RE: bga key on w210 - daxxer - 12-30-2016
(12-30-2016, 07:47 PM)bawarek Wrote: For the old 208/210 EIS I use only original NEC keys, never BE. I have tried a few BE long time ago, but they either not activate or stop working after a few hours/days.
i did many W202/208 or 210 only with BE keys and all working till today Pc
because more easy to use new BE key, then reprogramm some old NEC key whew
yes, sometime key not self-activated ( this have other solution...) Itwasntme
sometime key stop working after some time( this is quality of BE keys i think...because after replaced PCB in key working without any problems) Kolo
RE: bga key on w210 - PedroX5 - 12-30-2016
intersted information! Did you tried to re-read key after he stop working, to check why it stop work? Remote control stop work too?
RE: bga key on w210 - bawarek - 12-31-2016
The BE keys that did not work/stopped working with 208/210 EIS were reprogrammed and reused without any problems, so it was not defective keys problem. Overall I use 20-30 BE keys a month and only a few of them are really defective. On all other EIS models no problems whatsoever.
RE: bga key on w210 - Jan1980 - 01-25-2017
No no no. No need to have time for activating.. :-)
I know the problem on older HC05 EZS. Calculate key, open dump, then change "04 FC" to "14 EC", then save the dump and write it to the key !! Works directly without problems ! ;-)
Press THX and REP if it helps..
RE: bga key on w210 - mikeburnet - 01-25-2017
(01-25-2017, 05:05 AM)Jan1980 Wrote: No no no. No need to have time for activating.. :-)
have try this methode many times and for me did not work.
have done with activated key with MI, vvdibga, legend, manually and non worked. have try it on W202, W208, W210, W220(mcu 705) and not working for me.
RE: bga key on w210 - bawarek - 01-25-2017
I also have had some problems recently with original NEC keys inserted in a China case (BGA style). Because only half of the tip is transparent (like OEM BGA case) it partially obstructs the light.
RE: bga key on w210 - efka - 01-25-2017
the reason is that usually on old locks infrared is 90% dirty, lens is 90% worn out. ANd BE keys use different type of IR transmitter-receiver that works fine on good hardware but cant perform ok on old, worn out stuff .Tried and TRUE
just try again a BE key on a W220 with 705 mcu.
after insert the key like 60 times the ezs unlock and you can turn the key but
the key itself wont get activated. led in key stay on.
also left the key in the ezs for 3 hour but that also did not help.
then i try a nec key and get activated by third insertion from key.
then i try a BE key from noimmo and get same result. not activated.
