RE: Support thread for FullFixbySamik paid version - Delidj - 10-10-2026
Merhaba arkadaşım. Senden "Full Fix by Samik 9.2.5"i aldım.
Kurulum dosyası "xentry güncelleme hizmetini" içermiyor.
Hi, friend. I got the “Full Fix by Samik 9.2.5” from you.
The installation file doesn't include the “xentry update service.”
RE: Support thread for FullFixbySamik paid version - Sam!k - 10-10-2026
(10-07-2026, 12:32 PM)Autodiag2022 Wrote: I installed OpenShell 06/2026 and purchased SamFix specifically to use the C4 diagnostic toolkit.
Everything is activated and working correctly according to the activation status. I also successfully updated the C4 device through the Toolkit Administration.
However, I have a problem when connecting the C4 diagnostic interface to a vehicle.
Xentry successfully detects the vehicle and reads the VIN/chassis number, but after that it gets stuck on:
“THE DATA ARE BEING LOADED – PLEASE WAIT…”
It remains on this screen and does not continue to the vehicle identification/diagnostic session.
I have already checked the configuration and followed the recommended procedure, including switching between VCI mode and SDConnect mode and allowing the connection through the Windows Firewall.
The C4 device is detected correctly, and the VIN is read successfully, so communication with the vehicle appears to work initially. The problem occurs immediately after the VIN is read, when Xentry tries to load the vehicle data.
I have attached screenshots showing the problem.
Could you please advise me what needs to be changed or configured to resolve this issue?
Thank you in advance for your assistance.
Is that joke?
You install from fix only Toolkit, i think and it's working!
You have UserID "Xentry"?
Even not "XENTRY"?
You can't make UserID "Xentry" with my fix in any case!
Daimler blocked UserID Xentry a few years ago and who use it, see such picture as see you.
P.S. Read description and install fix on clean system, to avoid such problems and don't write that "SamikFix" didn't working.
(10-10-2026, 04:09 PM)Delidj Wrote: Merhaba arkadaşım. Senden "Full Fix by Samik 9.2.5"i aldım.
Why you think it should?
RE: Support thread for FullFixbySamik paid version - RacingProTeam - 10-15-2026
Hello there,
With the Xentry 06-2025 and the paid fullfix version i will be able to connect to Euro 6 Vans and Cars?
RE: Support thread for FullFixbySamik paid version - Sam!k - 10-16-2026
(10-15-2026, 07:44 PM)RacingProTeam Wrote: Hello there,
I don't know what is that😀
RE: Support thread for FullFixbySamik paid version - Delidj - 10-19-2026
(09-22-2024, 10:37 PM)Sam!k Wrote: Eğer FullFixbySamik'in ücretli sürümünü satın aldıysanız ve bir sorun yaşıyorsanız, tüm sorunlarınızı ve sorularınızı buraya yazın.
Bunu satış bölümüne yazmayın, çünkü
fantomel'in de belirttiği gibi , orası satış bölümüdür, destek bölümü değil.
Ücretsiz ve ücretli sürümler arasındaki farklar:
1. Xentry ve Daimler Truck, SDConnect ile çalışır.
2. DTS Monaco 9'un kolay kurulumu .
3. Xentry, Daimler Truck ve WIS 07.2021 otomatik aktivasyonu.
4. Yeni modellerin teşhisi için ZenZefi Satış Sonrası_STANDART sertifikaları.
5. Xentry ve Daimler Truck'ta kamyonlar için "Aktivasyonlar" sekmesi.
6. Xentry OpenShell 2025, Enet kablosuyla çalışır (yeni DoIP modelleriyle).
Anahtar tek bir sistem içindir!
Dizüstü bilgisayar için değil, Windows için değil, Xentry için değil ve Windows için de değil!
Bu, sistem formatlandıktan sonra, bazı donanımlar değiştirildikten sonra, herhangi bir adaptörün bağlanması veya çıkarılmasından sonra kabul edilebileceği veya edilemeyebileceği anlamına gelir; kabul edilmezse, yenisini satın almanız gerekir. Düzeltme ve ödeme bilgileri hakkında , FullFixbySamik'in son sürümünün
satış bölümü başlığında bilgi edinebilirsiniz . SSS Kendiniz yapamıyor musunuz? Bunu kendiniz yapmaktan emin değilseniz, "Uzaktan yapılandırma" seçeneğini sipariş edin ve biz sizin için uzaktan yapalım. Antivirüs programı programla çakışıyor mu? Microsoft Defender sorunsuz çalışır. Üçüncü taraf bir antivirüs kullanıyorsanız, kurulum ve etkinleştirme sırasında geçici olarak kaldırın. Program "İnternet yok" veya "Yanlış etkinleştirme anahtarı" diyor. Program, sunucumuza aktif bir internet bağlantısı gerektirir. Ağınız bağlantıyı engelliyorsa, farklı bir ağ veya VPN deneyin. FullFix'i kurdum ama Araç Setini bulamıyorum. Ana program yeni bir sürümse ve SDConnect desteği yoksa,  masaüstünde SDC4-VCI Switcher'ı arayın  . Bu araç, etkinleştirmeyi doğrulamak için internet bağlantısı gerektirir. Çalıştırın ve  SDConnect  modunu seçin. Birden fazla adaptörünüz varsa, yalnızca birini kullanmanız daha iyidir.  Sistem HWID'niz değişirse, SDC4-VCI Switcher artık çalışmaz . SDConnect için hangi IP adresini kullanmalıyım? SDConnect için 172.29.127.xxx aralığını kullanın. xxx kısmı 1-254 arasında herhangi bir sayı olabilir  ,  129 hariç . Örnek: 172.29.127.127 SDConnect ile DoIP için ek bir IP ekleyin: 169.254.0.35 SDConnect modunu seçtim, IP adresini yapılandırdım ve hala çalışmadı. VCI moduna geçin, güvenlik duvarını etkinleştirin, güvenlik duvarı ayarlarını varsayılan ayarlara sıfırlayın, SDConnect moduna geçin, güvenlik duvarı istediğinde bağlantıya izin verin, çalıştı. Toolkit hala SDConnect'i görmüyorsa, şunları kontrol edin:[/url]
Ethernet adaptörü, sürücü.
LAN kablosu.
SDConnect.
SDConnect'e güç verin.
SDConnect, Wi-Fi üzerinden DAS ile çalışmıyor mu?
Bunu
okuyun . Xentry etkinleştirilmedi. FullFix'i zaten çalıştırdıysanız ve hala "etkinleştirilmedi" mesajı görüyorsanız,  Güvenli Önyükleme'nin  devre dışı bırakıldığından emin olun ve FullFix'i yalnızca ilk (etkinleştirme) bileşeni seçili olarak tekrar çalıştırın. Etkinleştirme kodunu yapıştırdığımda DTS Monaco donuyor. Etkinleştirme kodunu yapıştırdığınızda DTS Monaco donuyorsa, kodu manuel olarak yazın. Genellikle Windows 11'de olur. 2026 sürümünde eklenti güncellemesinden sonra Xentry çalışmıyor ve 2221-1 hatası görüyorum? Bu gönderiyi okuyun .
[url=https://mhhauto.com/Thread-Support-thread-for-FullFixbySamik-paid-version?pid=3404308#pid3404308]
[font="MHH Font", sans-serif]Hi, friend. I got the “Full Fix by Samik 9.2.5” from you.[/font]
[font="MHH Font", sans-serif]The installation file doesn't include the “xentry update service[/font]
RE: Support thread for FullFixbySamik paid version - Sam!k - 10-19-2026
(10-19-2026, 03:40 PM)Delidj Wrote: [font="MHH Font", sans-serif]Hi, friend. I got the “Full Fix by Samik 9.2.5” from you.[/font]
Did i promised you such program?
I don't remember.
Did you read it somewhere?
If yes, where?
Do you know what is xentry update service?
It's component of Xentry, if Daimler delete it, need to ask them to bring it back.
RE: Support thread for FullFixbySamik paid version - rober.marcos - 10-19-2026
What is the latest version of Daimler Truck software that works with SD Connect and provides access to Euro 6 trucks?
RE: Support thread for FullFixbySamik paid version - Wetwiki - 10-21-2026
(10-19-2026, 11:41 PM)rober.marcos Wrote: What is the latest version of Daimler Truck software that works with SD Connect and provides access to Euro 6 trucks?
SDconnect works with any Daimler Truck if fixed !
Euro 6 >>> is engine & enviro Apprev >>> does not relate to Diagnose SW (DT/XDOS can diagnose aolt of trucks with tht sys)
Euro 6 >>> is engine & enviro Apprev >>> does not relate to Diagnose SW (XDOS can diagnose alot of cas/vans with tht sys)
RE: Support thread for FullFixbySamik paid version - Delidj - 10-21-2026
I don't remember.
If yes, where?
Hi, Samik,
I didn't promise you that, but I see it in the screenshots and installation videos for other Samik programs. It appears at the 15-second mark in your video:        https://www.youtube.com/watch?v=1aPLo6bwm3Y    If you have it, I'd like to install it.
