2007 MB E220CDI 170PS don't start. - Printable Version
+---- Thread: 2007 MB E220CDI 170PS don't start. (/Thread-2007-MB-E220CDI-170PS-don-t-start)
2007 MB E220CDI 170PS don't start. - sigaik - 01-13-2017
I have changed ECU. Cloned ori ecu with used one. Programmed online with Star Diagnose.
ECU DCM 3.2 CRD.11
Checked Driver Authorization and have this, what to do?
RE: 2007 MB E220CDI 170PS don't start. - shmuk - 01-13-2017
i think you should to do virgin ecu before personalized, did you virgin ecu ?
RE: 2007 MB E220CDI 170PS don't start. - gio777 - 01-14-2017
Driver Authorization are OK
RE: 2007 MB E220CDI 170PS don't start. - mb_port - 01-14-2017
(01-13-2017, 11:27 PM)sigaik Wrote: I have changed ECU. Cloned ori ecu with used one. Programmed online with Star Diagnose.
ECU DCM 3.2 CRD.11
drive authorization ok
turn key to 50 and give 12v to purple cable on sam front
fuse for starter relay ok?
RE: 2007 MB E220CDI 170PS don't start. - sigaik - 01-14-2017
ECU DCM 3.2 CRD.11
Starter are ok, engine cranck but it will not fire up
start and see with xentry actual value- high pressure
(01-14-2017, 04:20 PM)mb_port Wrote: start and see with xentry actual value- high pressure
All data looks okay, low and high pressure.
I have messured injectors and it is no power to injectors, ground is okay.
donor ecu tested bevore swap?
No, not tested.
Maybe trying another ecu?
