Vito w447 not crank terminal 15 not power - Printable Version
+---- Thread: Vito w447 not crank terminal 15 not power (/Thread-Vito-w447-not-crank-terminal-15-not-power)
Vito w447 not crank terminal 15 not power - NEGOCAUTO33 - 09-07-2023
Hello
Have big headache with w447 terminal 15 0v , not crank…
Gearbox not communication
Have check fuse for gearbox 0 v and relay gearbox not power 0  ( is terminal 15 supply voltage )
Have see all line terminal 15 exemple wire in fan normaly have 12 v but have 0 volt in my…
For that problem is terminal 15 I think wire dead enter ECU MOTOR AND GEARBOX
who have find same problem
Help is welcome Smile
https://ibb.co/0rZfp4F
https://ibb.co/6v3FCPK
Some dtc picture attached
RE: Vito w447 not crank terminal 15 not power - TKS12 - 09-07-2023
(09-07-2023, 01:38 AM)NEGOCAUTO33 Wrote: Hello
Hi MHH Friend look under the right sit there is an big fuesbox mit many fuses from 50 to 300 amp  i hope there is your problem
wen was helpful th an rep
Br Tks12
RE: Vito w447 not crank terminal 15 not power - NEGOCAUTO33 - 09-14-2023
Br Tks12
Hi
I have check all fuse is ok
RE: Vito w447 not crank terminal 15 not power - vvia_Kirr - 09-14-2023
Br Tks12
Hi
Can you communicate with engine ecu? What is status of terminal 15 in EIS and SAM ecu?
Br Tks12
Hi
yes engine écu com ok
ezs com ok
will check status of 15 in ezs and sam but 15 in sam not have cause some fuse of gearbox and another élément supply to the terminal 15 0v
ecu not communication is gearbox
thanks
RE: Vito w447 not crank terminal 15 not power - vvia_Kirr - 09-15-2023
Br Tks12
Hi
ezs com ok
thanks
Check gerabox fuse according to wiring diagram
RE: Vito w447 not crank terminal 15 not power - Magic - 09-16-2023
You must go backwards from Gearbox feed, If there is 0V then check fuse "227" in K40/10 (Engine compartment)
If the fuse is ok, then measure if you have Circuit 15 (12v) there, if not, then locate Circuit 15 relay "R"
and measure Circuit 30 (12v) on leg "30" and 12v on leg "86" from SAM.
If this Circuit 15 Relay "R" is not not working a lot of electronics would not work.
RE: Vito w447 not crank terminal 15 not power - NEGOCAUTO33 - 09-16-2023
(09-16-2023, 03:36 AM)Magic Wrote: You must go backwards from Gearbox feed, If there is 0V then check fuse "227" in K40/10 (Engine compartment)
Hi and
Thanks friend for you great help  Smile
Have 0 v in plug gearbox right ( gearbox  is supply by terminal 15 …terminal 15 supply « fan » too right but same 0 volt to small wire in fan motor….for that it’s terminal 15 problem all component supply with terminal 15 = 0 v
that car put me crazy…fuse + relay on sam for gearbox = 0 v not power…
Circuit 15 relay R ( K) find not power same :/
Great thanks again for you great help
Best Regards
RE: Vito w447 not crank terminal 15 not power - vvia_Kirr - 09-16-2023
Hi and
Best Regards
If there are no power on all terminal 15 components,  then you should start from checking teminal status in SAM control unit. Also check incoming power supply on fuse box.
