WIS standalone start key not saving - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: WIS standalone start key not saving (/Thread-WIS-standalone-start-key-not-saving) |
WIS standalone start key not saving - Pffiukas - 05-25-2026 Morning , WIS just stopped working. Tried uninstalling wis and the config tool. Attached video. RE: WIS standalone start key not saving - job - 05-25-2026 which version ? RE: WIS standalone start key not saving - garfild - 05-25-2026 Your lic_key_2.dat file is locked to edits + some patches making the own backup of this file and make copy back and forward, I faced similar issue. Since the WIS key is saved in the same file, you need to unlock the edit, load your WIS key and lock again. RE: WIS standalone start key not saving - Pffiukas - 05-25-2026 (05-25-2026, 02:47 PM)job Wrote: which version ?21/7 (05-25-2026, 02:51 PM)garfild Wrote: Your lic_key_2.dat file is locked to edits + some patches making the own backup of this file and make copy back and forward, I faced similar issue. Since the WIS key is saved in the same file, you need to unlock the edit, load your WIS key and lock again.Windows can't even find a file like that. Where it's located? Thanks. RE: WIS standalone start key not saving - garfild - 05-25-2026 check C:\ProgramData\LicDir\ or older c:\Documents and Settings\All users\Application data\licdir\ RE: WIS standalone start key not saving - Pffiukas - 05-25-2026 (05-25-2026, 03:56 PM)garfild Wrote: check C:\ProgramData\LicDir\ or older c:\Documents and Settings\All users\Application data\licdir\Removed the read only and it's working. Thanks!
