WIS standalone start key not saving
Morning ,
WIS just stopped working. Tried uninstalling wis and the config tool. Attached video.
.txt
New Text Document.txt
28 bytes
which version ?
DTS9.04.016
MB software
M6+ Pro,C3
DS,Citroen,Peugeot Online
Lexus online//LatestGTS+2026 Offline/DST010
Your lic_key_2.dat file is locked to edits + some patches making the own backup of this file and make copy back and forward, I faced similar issue. Since the WIS key is saved in the same file, you need to unlock the edit, load your WIS key and lock again.
Thanks given by: Pffiukas , deo
(05-25-2026, 02:47 PM)job Wrote: which version ?
21/7
(05-25-2026, 02:51 PM)garfild Wrote: Your lic_key_2.dat file is locked to edits + some patches making the own backup of this file and make copy back and forward, I faced similar issue. Since the WIS key is saved in the same file, you need to unlock the edit, load your WIS key and lock again.
Windows can't even find a file like that. Where it's located? Thanks.
check C:\ProgramData\LicDir\ or older c:\Documents and Settings\All users\Application data\licdir\
(05-25-2026, 03:56 PM)garfild Wrote: check C:\ProgramData\LicDir\ or older c:\Documents and Settings\All users\Application data\licdir\
Removed the read only and it's working. Thanks!  Cheer2
Yesterday, 12:52 PM
06-12-2026, 07:11 AM
05-29-2026, 01:56 PM
