Help sd connect settings for xdos - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Help sd connect settings for xdos (/Thread-Help-sd-connect-settings-for-xdos) Pages:
Help sd connect settings for xdos - clive_pather - 12-08-2015 Hi all can someone please tell me the ip setting for connecting LAN cable to C4 using xdos (win7) RE: Help sd connect settings for xdos - laco210 - 12-08-2015 Same like on XP 172.29.127.119 and 255.255.0.0 RE: Help sd connect settings for xdos - clive_pather - 12-08-2015 (12-08-2015, 12:58 AM)laco210 Wrote: Same like on XP 172.29.127.119 and 255.255.0.0 i have tried that but no connection RE: Help sd connect settings for xdos - laco210 - 12-08-2015 Cable connectors all is ok? Try connect internet through this lan cable. On XP system lan connection is ok? RE: Help sd connect settings for xdos - clive_pather - 12-08-2015 can connect to internet using lan cable, please send me a screen shot of your lan properties. RE: Help sd connect settings for xdos - webmaster - 12-08-2015 1st Open Sdconnect Toolkit and see if ur mux appear over there or not. 1: If yes, simply select it 2: If No, Then there is no any communication between MUX and PC To use net on LAN and use the sdconnect on later time without touching the LAN IP, follow this: Put the IP of Ur router as follows ( 4ex) 192.168.1.101 ( Just example ) 255.255.255.0 192.168.1.1 192.168.1.1 And then Click Advanced ==> Add ( you will get new window where you have to put IP address and Subnet Mask Put as follows: 172.29.127.99 255.255.0.0 Click OK ( Done ) If you want to connect Infrastructure ( Net and SDconnect @ same time Via Wireless or LAN and wireless ) I must do it on ur PC because I feel hard to explain. Best regards. RE: Help sd connect settings for xdos - clive_pather - 12-08-2015 (12-08-2015, 12:45 PM)webmaster Wrote: 1st Open Sdconnect Toolkit and see if ur mux appear over there or not. Hi , can you help me setup via teamviewer? Thanks guys , all working fine now RE: Help sd connect settings for xdos - webmaster - 12-08-2015 Sure... Drop me ur ID and Pass Via PM. Best regards. RE: Help sd connect settings for xdos - passador83 - 11-18-2016 (12-08-2015, 09:26 PM)webmaster Wrote: Sure... Hello sir, i have the same problem. Can you help me by team viewer? |
