  • 31 Vote(s) - 2.81 Average
Help sd connect settings for xdos
Hi all
can someone please tell me the ip setting for connecting LAN cable to C4 using xdos (win7)
Same like on XP 172.29.127.119 and 255.255.0.0
Thanks given by: Rocinante , clive_pather , webmaster
(12-08-2015, 12:58 AM)laco210 Wrote: Same like on XP 172.29.127.119 and 255.255.0.0
i have tried that but no connection
Cable connectors all is ok? Try connect internet through this lan cable. On XP system lan connection is ok?
can connect to internet using lan cable, please send me a screen shot of your lan properties.
1st Open Sdconnect Toolkit and see if ur mux appear over there or not.
1: If yes, simply select it
2: If No, Then there is no any communication between MUX and PC
To use net on LAN and use the sdconnect on later time without touching the LAN IP, follow this:
Put the IP of Ur router as follows ( 4ex)
192.168.1.101 ( Just example )
255.255.255.0
192.168.1.1
192.168.1.1
And then Click Advanced ==> Add ( you will get new window where you have to put IP address and Subnet Mask
Put as follows:
172.29.127.99
255.255.0.0
Click OK ( Done )
If you want to connect Infrastructure ( Net and SDconnect @ same time Via Wireless or LAN and wireless )
I must do it on ur PC because I feel hard to explain.
Best regards.
[Image: mhhsig.gif]
(12-08-2015, 12:45 PM)webmaster Wrote: 1st Open Sdconnect Toolkit and see if ur mux appear over there or not.
255.255.255.0
192.168.1.1
192.168.1.1
Put as follows:
172.29.127.99
255.255.0.0
Click OK ( Done )
Best regards.
Hi , can you help me setup via teamviewer?
Thanks guys , all working fine now
Sure...
Drop me ur ID and Pass Via PM.
Best regards.
[Image: mhhsig.gif]
Thanks given by: ToMiBoY , pesona , boston , aliguard
(12-08-2015, 09:26 PM)webmaster Wrote: Sure...
Best regards.
Hello sir, i have the same problem. Can you help me by team viewer?
