bootloader active ntg5 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: bootloader active ntg5 (/Thread-bootloader-active-ntg5) |
bootloader active ntg5 - camber53 - 12-12-2015 hi bros I have a ntg5 stuck at bootloader active does any kind bros here know how to solve ? ![]() ![]() thank you RE: bootloader active ntg5 - Umzzzzz - 12-12-2015 The way we do it at work is through the BD rom we connect bluray dvd player into the XENTRY connect multiplexer and then load the required BD rom in the bluray play and carry out the update and programming through xentry. RE: bootloader active ntg5 - forestml - 12-15-2015 You was flashing and flash process was not finished? did you try start flashing one more time over Monaco? (12-12-2015, 02:40 PM)camber53 Wrote: hi bros RE: bootloader active ntg5 - camber53 - 12-15-2015 (12-15-2015, 01:33 AM)forestml Wrote: You was flashing and flash process was not finished? yes but same error came out there is 3 files to flash ? RE: bootloader active ntg5 - kman2k - 12-20-2016 I have exact same problem ... after try update the firmware on the HU5s1 unit. Please anyone ! is there a way to fix it or I should give up ? Thanks
RE: bootloader active ntg5 - ladadens - 12-20-2016 insert update sd kard fro the tg5 .rest will do the system alone without you.yopu only need to wait untill it do his work. after self restart the system should work as before.this is from playing in the hidden menüs. RE: bootloader active ntg5 - camber53 - 12-21-2016 where can we get the sd card for flashing ? thank you RE: bootloader active ntg5 - kman2k - 12-21-2016 (12-20-2016, 04:40 PM)ladadens Wrote: insert update sd kard fro the tg5 .rest will do the system alone without you.yopu only need to wait untill it do his work. where can i get or buy that SD cards you just mentioned ? thanks |
