Umzzzzz
Location OfflineJunior Member
0
Thanks Given: 27
Thanks Received: 26 (14 Posts)
34
The way we do it at work is through the BD rom we connect bluray dvd player into the XENTRY connect multiplexer and then load the required BD rom in the bluray play and carry out the update and programming through xentry.
325
Thanks Given: 1123
Thanks Received: 2626 (2026 Posts)
8,209
108
insert update sd kard fro the tg5 .rest will do the system alone without you.yopu only need to wait untill it do his work.
after self restart the system should work as before.this is from playing in the hidden menüs.
17
Thanks Given: 270
Thanks Received: 85 (46 Posts)
226
41
where can we get the sd card for flashing ?
thank you
Please press
![[Image: DdOoHyJ.jpg]](http://i.imgur.com/DdOoHyJ.jpg)
buttons if my post helped
