Mercedes W204 Stuff - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Mercedes W204 Stuff (/Thread-Mercedes-W204-Stuff) Pages:
Mercedes W204 Stuff - hipeboy - 02-17-2016 Hi, I own a W204 C220CDI BE with 7G tronic from September/2011. I'm looking for a original ECU file for the hardware ID A6519007500. It's the Delphi CRD3.10. I'm looking for 2 versions: - Engine OM651 : 220CDI BE (170hp) Automatic - Engine OM651 : 250CDI BE (204hp) Automatic Looking to do some mods: - Flash the ECU: 220CDI -> 250CDI original file (OM651 same engine) - 7G Tronic (software update, reset the learned data) - Disable the torque limiter - Throttle pedal response curve (to be more responsive) - Update of the telematics - Turn off eco mode (start/stop) - DPF OFF - EGR OFF - Adblue OFF - Calibration of the parking sensors (I dont know if its possible) - Instrument clusters in silver Can anyone help me with any of these? Thanks a lot. Best regards. RE: Mercedes W204 Stuff - benzcoupe - 02-17-2016 Be careful of SW update for 7G its easy to brick those modules just by looking at them funny. they are touchy in diagnostic mode even with SDS dealerships uses voice of experience talking here thank god i was not a flat rate tech its generally agreed that its a stupid place for a module wtf were they thinking really...THAT one module by itself severely damaged MB's previously solid reputation which it still has NOT recovered... if it were MINE i would change the ATF every 60K using only the highest quality available since only 50% of fluid can be drained from pan at best...Unless u have anothervirgin valvebody ready to go would i do anything more than look at fault codes maybe an actuation but updateing firmware and /or SW is playing with fire RE: Mercedes W204 Stuff - hipeboy - 02-17-2016 Thanks a lot for your response. Well, I'm newbie to this stuff. Will let the SW update for the 7G out of my plans ![]() With Vediamo is possible to change the engine power output? How can I do it? Mercedes W204 Stuff - hipeboy - 02-20-2016 Hi Can anybody give me some tips to do this stuff? Thanks. Mercedes W204 Stuff - hipeboy - 02-27-2016 Anyone has the original file of the 250 CDI with ECU CRD3.10 or can recommend a reputable file tuner company? Thanks. RE: Mercedes W204 Stuff - trigital - 02-28-2016 (02-27-2016, 05:47 PM)hipeboy Wrote: Anyone has the original file of the 250 CDI with ECU CRD3.10 or can recommend a reputable file tuner company? 250CDI aka 204 HP has forged pistons and also different turbine management, so this software will melt your steel pistons at once... Why do you need Adblue Off on MY 2011 W204? RE: Mercedes W204 Stuff - hipeboy - 02-28-2016 Hi, I thought the engine OM651 twinturbo was 100% the same between 220CDI and 250CDI and that the only difference was the engine management. Can anyone confirm this? Thanks. RE: Mercedes W204 Stuff - Aless91 - 02-28-2016 Trigital is right and already explained the difference. I already said to you that it is not the same. 200 and 220 are the same but not 250. Adblue does not exist on 2011 204 car. Mercedes W204 Stuff - hipeboy - 02-28-2016 Thanks for your response Aless91. As far as I know the OM651 200CDI is single turbo and the OM651 220/250 CDI are two stage turbo. Where can I found the differences? In EPC? |
