hipeboy
Location OfflineJunior Member
0
Thanks Given: 37
Thanks Received: 2 (2 Posts)
29
02-17-2016, 03:10 AM
(This post was last modified: 02-17-2016, 01:37 PM by hipeboy.)
I own a W204 C220CDI BE with 7G tronic from September/2011.
I'm looking for a original ECU file for the hardware ID A6519007500.
It's the Delphi CRD3.10.
I'm looking for 2 versions:
- Engine OM651 : 220CDI BE (170hp) Automatic
- Engine OM651 : 250CDI BE (204hp) Automatic
Looking to do some mods:
- Flash the ECU: 220CDI -> 250CDI original file (OM651 same engine)
- 7G Tronic (software update, reset the learned data)
- Disable the torque limiter
- Throttle pedal response curve (to be more responsive)
- Update of the telematics
- Turn off eco mode (start/stop)
- DPF OFF
- EGR OFF
- Adblue OFF
- Calibration of the parking sensors (I dont know if its possible)
- Instrument clusters in silver
Can anyone help me with any of these?
Thanks a lot.
Best regards.
Thanks Given: 203
Thanks Received: 79 (47 Posts)
114
Be careful of SW update for 7G its easy to brick those modules just by looking at them funny. they are touchy in diagnostic mode even with SDS dealerships uses voice of experience talking here thank god i was not a flat rate tech its generally agreed that its a stupid place for a module wtf were they thinking really...THAT one module by itself severely damaged MB's previously solid reputation which it still has NOT recovered... if it were MINE i would change the ATF every 60K using only the highest quality available since only 50% of fluid can be drained from pan at best...Unless u have anothervirgin valvebody ready to go would i do anything more than look at fault codes maybe an actuation but updateing firmware and /or SW is playing with fire
hipeboy
0
Thanks Given: 37
29
02-20-2016, 05:32 PM
(This post was last modified: 02-20-2016, 05:32 PM by hipeboy.)
Hi
Can anybody give me some tips to do this stuff?
Thanks.
hipeboy
0
Thanks Given: 37
29
02-27-2016, 05:47 PM
(This post was last modified: 02-27-2016, 05:51 PM by hipeboy.)
Anyone has the original file of the 250 CDI with ECU CRD3.10 or can recommend a reputable file tuner company?
Thanks.
123
Thanks Given: 464
Thanks Received: 653 (503 Posts)
1,425
13
(02-27-2016, 05:47 PM)hipeboy Wrote: Anyone has the original file of the 250 CDI with ECU CRD3.10 or can recommend a reputable file tuner company?
Thanks.
250CDI aka 204 HP has forged pistons and also different turbine management, so this software will melt your steel pistons at once...
Why do you need Adblue Off on MY 2011 W204?
MBRetrofit Map Codes, Remote Star3 Coding
hipeboy
0
Thanks Given: 37
29
I thought the engine OM651 twinturbo was 100% the same between 220CDI and 250CDI and that the only difference was the engine management.
Can anyone confirm this?
Thanks.
1,884
Thanks Given: 71
Thanks Received: 4437 (720 Posts)
971
51
02-28-2016, 01:17 AM
(This post was last modified: 02-28-2016, 01:17 AM by Aless91.)
Trigital is right and already explained the difference. I already said to you that it is not the same. 200 and 220 are the same but not 250.
Adblue does not exist on 2011 204 car.
hipeboy
0
Thanks Given: 37
29
02-28-2016, 01:35 AM
(This post was last modified: 02-28-2016, 02:31 PM by hipeboy.)
Thanks for your response Aless91.
As far as I know the OM651 200CDI is single turbo and the OM651 220/250 CDI are two stage turbo. Where can I found the differences? In EPC?
