  • 1 Vote(s) - 5 Average
(SOLVED)WIS/EPC SERVICE ACCESS AUTHORIZATION PROBLEM!
please help me to fix  Sever access authorization problem of WIS/EPC!
Thank!
Support installing: XENTRY XDOS/PASSTHRU 07.2019, ISTA4.17.23, ODIS 5.13, FORD IDS, JLRSDD v156
My viber, whatsapp: +84978928544
Thanks given by: cunninghamgarage
(08-21-2019, 09:22 PM)peter_pan Wrote: please help me to fix  Sever access authorization problem of WIS/EPC!
Thank!
Hi
Try update your I.E. to I.E. Version 11
Best Regards
If my post can help you , Thanks + Reputation will be appreciated  Kolo
Thanks given by: peter_pan
i have this issue too.
the mac address always changes. i only use it for xentry(cd4 via lan) and i dont even turn on the wifi.
so changing keys is the only daily solution.
~If I helped, press "thanks" and "reputation". Thanks!~
Thanks given by: ManitouSmoke
I updated IE 11. Wis work fine. And starfinder limited function
Sent from my iPhone using Tapatalk
(08-22-2019, 09:13 AM)peter_pan Wrote: I updated IE 11. Wis work fine. And starfinder limited function
Hi
Small tips
about the star finder limited problem is on Design Review 2013
Best Regards
Try this solution.
https://mhhauto.com/Thread-XENTRY-DAS-AC...5#pid69065
Thanks given by: vijayrelia , philbradf , nvggvn , jemilalicheroy
Thank!
Hi! how did you solved?
? Any solution to this issue ? :
No valid server access authorization. Creation of workshops, groups and users not possible. Restricted changes only possible.
Fixed that issue by
1.unisltalling EWA and Java from control panel
2.delete :\Program Files (x86)\EWA and :\DB
3.installing everything by default on C: , previously i installed it on another drive.
This fixed my issue.
[Image: OE8W.gif]
Yesterday, 03:43 PM
Yesterday, 12:52 PM
06-12-2026, 07:11 AM
