2021 Tiguan Remote Start thru ODIS
Hey all,
I'm trying to install a factory remote start on my 2021 Tiguan SE. I installed everything and was entering the SWAP codes and following along with the steps, but it keeps asking me for a dealer username and password...is this in impossible DIY install or is there a workaround for the online bit? Thanks!
(12-31-2023, 10:54 PM)Fatalslink Wrote: Hey all,
You need online access, without that its not gonna work
Airbag Crash Resets
Mail In UK only Airbag Crash Reset
Do you know if any of those "geko" services work with this?
write exactly what you want to install. part number. retrofit or parts replacement?
if I helped, please THANKS and REP Tup
R1200GS LC ADV, GP1800 SVHO
If u need Online Access just Pm Me
Online Coding Vw, Skoda , Audi , Seat - Via Odis No Charge When Failed - I Can Immo Off /Clone All Dsg And all Also Edit Mileage for All Dsg/ Med17 - edc17- simos18 , Immo off - Clone All edc17 med17,Pcr2.1 ,radio code , component protection . Odis 23 & Odis 17 instillation and Activation
I had the SWAP codes installed online. Now the problem is that it is a 2021 tig and you have to use the extended range kit. When I go to the OBD section of ODIS to adapt rf transmitter via barcode and type in the hex key and pass key of the remote and hit start, it gives me this message "usds basic settings terminated for safety reasons" and won't copy the keys to the remote start system.
(12-31-2023, 11:35 PM)yarowsc Wrote: write exactly what you want to install. part number. retrofit or parts replacement?
[font="VW Text Light", arial, helvetica, san-serif]Part Number[/font][font="VW Text Light", arial, helvetica, san-serif]: [/font][font="VW Text Light", arial, helvetica, san-serif]NPN065005[/font]
[font="VW Text Light", arial, helvetica, san-serif]And clean install direct from vw online.[/font]
Yesterday, 03:35 PM
06-13-2026, 10:08 PM
06-12-2026, 04:26 PM
