FORD Technical Information System (TIS) Outcode/Incode
I want to change a BCM Module on a Ford Smax from 2008. I have a used BCM Module and need to write immo form ca in module.
With autel I can generate a outcode from the module. Now I need a incode and for this I need a outcode/incode generator.
Can someone help me?
Greetings from germany
Post out code I should be able to get u in code for this model year u can dm me also if u want to remember out code changes with each ignition cycle so u have to keep ignition on till u input in code
I like to help, Please Leave Rep + Thankyou IF I HELPED YOU....
Autel Ultra S2/IM608S/KM100/ITS600, OBDstar key master plus C/DC706, Key tool plus/max pro/mini, KT200II, IO-Prog, Xentry SDconnect C4, PIWIS 3 VAS6154, KESS/KTAG, Multi-Prog, BIMTOOL PRO, KR55
(05-31-2026, 09:32 PM)Davidpetrisor Wrote: Post out code I should be able to get u in code for this model year u can dm me also if u want to remember out code changes with each ignition cycle so u have to keep ignition on till u input in code
I have sent you a PM
Send the code and we'll see what we can do.
06-13-2026, 03:44 AM
06-09-2026, 06:07 PM
Ford
06-05-2026, 08:41 PM
