313
Thanks Given: 572
Thanks Received: 492 (33 Posts)
191
43
11-11-2016, 12:19 AM
Thank everyone for helping out on this
I have a 99 s600 w140 body that the key want open the trunk and now broke the key trying so waiting to get a new key made and keep on trying
So far i have put tried using the trunk release switch and the central locking switch with no results , the trunk release on the FOB key also is not working as well
Tried opening the back where the First Aid kit is and not able to do anything with that.
Any help would be appreciated
Thank you in advance
581
Thanks Given: 330
Thanks Received: 874 (149 Posts)
412
15
Its difficult to help without scanning systems for faults and live data values and post your results you may have just broken wires at hinge and key lock is just seized from lack of use but without seeing the car or scan results we can only guess!
313
Thanks Given: 572
191
43
Thank you for the update in the next few days i will get a key and see if any error codes , The car was driving fine just that the trunk does not open, and it looks like the central lock is also not working as well
453
Thanks Given: 444
Thanks Received: 1578 (376 Posts)
670
57
If it helps.... under rear seat.Air Pump module....... (cracked hose inside)
313
Thanks Given: 572
191
43
still waiting for Key from Mercedes, they gave me a valet as the remote is on backorder
However cannot open trunk and PSE pump not working
Anyone know of a way to get open the trunk
I was also told seeing this is a 99 if i get the PSE pump fixed i will still need to activate / program the new PSE pump if i do that
Any help in opening this trunk would be appreciated
as far as the code , evrything looks fine , no error code however just using a standart reader
2,095
Thanks Given: 14574
Thanks Received: 17429 (4938 Posts)
6,536
46
Is this a W140 or a W220? There is an extensive thread about getting into a W220 trunk..
______________________________________________________________________________________
453
Thanks Given: 444
670
57
did you try simply disconnect, reconnect PSE?
