  • 8 Vote(s) - 2.88 Average
2003 R230 SL500 instrument cluster communication error
Hello gents,
As the title says I have a 2003 R230 SL500 which has an instrument cluster communication error, it's the only module that I can't connect with sds machine. Cluster works fine I put it in a friends car and can connect to it just fine, only in my car it won't connect, seems I have some CAN issue and cluster is not seen on the network, has anyone ever experienced anything similar?
Mike
Show the error message in your fault memory as well as the DAS error you're getting when you try to connect.
It's the same error as if you have a module unplugged, I will post a picture tomorrow.
First make sure you have all your powers and grounds.. Next see if you have CAN voltage at the cluster connector, if it has a K-line to the X11/4 make sure that wire isn't shorted or open...
