14
Thanks Given: 30
Thanks Received: 80 (27 Posts)
132
34
(05-30-2023, 02:21 AM)massiy1 Wrote: (05-29-2023, 09:28 PM)pkutish Wrote: (05-29-2023, 01:50 PM)massiy1 Wrote: (05-29-2023, 09:19 AM)pkutish Wrote: (05-29-2023, 05:26 AM)massiy1 Wrote: [font="MHH Font", Calibri, sans-serif]ciao ragazzi, ho appena modificato l' ewanapi.ini come detto sopra, ma quando apro epc o wis asra java mi da questo errore? Avete soluzioni per favore?
grazie
P.S. allego la foto dell'errore[/font]
Ciao,
hai modificato anche server.xml e core_cfg.xml? E quali modifiche hai apportato a ewanapi? non ricordo che tu abbia bisogno di toccare questo file. Se hai bisogno di aiuto posso aiutarti a reinstallare/configurare WIS/ASRA tramite teamviewer.The file jnlp have the port wrong
Migliore
yes I modified server and core.The problem seems to be java using port 9000 and not 9010 which I gave it.
Something is definitely missing in your config. as it indeed sends you to unavailable port. Send me PM as i assume you're in Italy and myself in Canada, as i mentioned i can jump on teamviewer and fix it, no charge of course
Best!
thank you so much pkutish for helping me in configuring wis epc.I owe you a beer my friend!!!
What was missing from the config as my java is also pointing to the old port
Chris
2019 E220 W213
Break it to make it!
Thanks Given: 105
Thanks Received: 70 (64 Posts)
383
30
What folder or file needs changing?
Thanks Given: 105
383
30
I don't have XUS or XDOS installed
Thanks Given: 105
383
30
Seem to have a problem with EWA application server it won't start.
Thanks Given: 90
Thanks Received: 20 (16 Posts)
60
Maybe I'm wrong but if you can't find line with 'datacard' then maybe you just not activated this function, or it's only for tandem EPC+WIS
Try simply to change other places, restart computer and check.
