  • 112 Vote(s) - 3.27 Average
GM TIS2000
64
found out how and worked perfectly. here are the instructions.
1. Click on the configuration drop-down menu and select IO Management.
2. On the IO Management screen, click DRIVER to add J2534
support to TIS. In the INSTALL DRIVER box, type or browse to
c:\program files\cosids\bin\j2534.dll and click INSTALL. This
will install the driver and bring you back to the IO management screen.
3. On the IO Management screen, click ADD to add the new
interface. For the LOGICAL NAME type “Generic Pass Thru” and for
Driver choose “J2534 Pass Thru Driver”. You must type the LOGICAL NAME exactly as shown with a single space between words and capital G, P, T.
If you mistype even one character or miss a space it will not work!
4. On the IO Management screen select 'Generic Pass Thru', click PROPERTIES and choose a specific J2534 device. In the DEVICE NAME list choose YOUR J-2534 device.
Return to this screen if you want to change to another J-2534 device later.
5. Close IO management and choose Service Programming System.
Use the new GENERIC PASS THRU option as your diagnostic interface.
65
(06-04-2015, 02:03 AM)avjz79 Wrote: found out how and worked perfectly. here are the instructions.
I followed these directions exactly but in step 4, my device name list is empty. I am able to connect to my MDI using MDI Manager. Any ideas how to fix this?
Works perfect with Bosch M VCI
Anyone have a tis2000 link/torrent???
(08-19-2016, 01:34 AM)HighlanderX Wrote: Anyone have a tis2000 link/torrent???
TIS 2000 116 Multilanguage
Smile
Thanks given by: fila91
69
You are my hero mate049653
This solution worked for me.Cheer2
Tup
Thanks and rep added.
Thanks given by: Bianconi2
70
Tup
thanks friend this setup have done it before on tis 2000 and maxiflash now iam tryng to use a vcm2 but have no luck any one have updated drivers for vcm2 thank you
Hi everybody,
Is it possible to have a link for a good working TIS2000? I really need the software and appreciate your help. Thanks,
Also, where can I get the calibration files? Is it included with the software?
(06-04-2015, 02:03 AM)Oavjz79 Wrote: found out how and worked perfectly. here are the instructions.
Hi. Do you send me link tis2000 for mega?  Tks
If I helped and you like it, please click +1 GIVE REPUTATION and +1THANKS
Thanks given by: badassmthrfkr
Opel
05-25-2026, 11:51 AM
Vauxhall
05-14-2024, 02:10 PM
05-11-2022, 04:18 PM
