  • 202 Vote(s) - 3.17 Average
1,720
(05-06-2025, 05:54 PM)art_arev Wrote: Hi guys. I wonder if someone can help me. My laptop has 2 discs C & D. EWA was installed on C drive & databases were installed in D drive. EPC & WIS were installed & all was working perfectly. The D drive was starting to fail so I replaced the drive with a new one. The new drive has a letter E. Now when I try to open both EPC & WIS , I get an error cant access database.  How & were do I change configuration showing the program that database (DB folder) is in E drive.
Thanks again
Why not change the drive letter through windows disk management if you don't know how to do it via EWA configuration settings?
Thanks again
  Disk Management & other much more powerful disk management tools won't allow you to keep the same drive letter..........
Art Tup
Thanks guys all sorted. I just uninstalled EWA & reinstalled it & pointed the software to drive E
All my EPC keygens for whatever reason are not giving a key with active datacard.
Can someone please give me a working key with datacard
Mac : C8D9D2ECECF2
Art Tup
(05-07-2025, 05:10 AM)sztuka_arev Wrote:       Mac: C8D9D2ECECF2
Try:
EPCnet: FP5ALALP26JHHAJ7GDHBUAJCHZBU2E82QDSHA65J38A78AN9
WISnet: Z4SEH2RFSBE6YD8A62GQTVTLZWVEMYBRU7AVWCNF7D7RJWB5
(05-06-2025, 11:34 PM)art_arev Wrote:   Disk Management & other much more powerful disk management tools won't allow you to keep the same drive letter..........
Here the failing disk was not the OS drive ©. EWA data base was on drive D that failed. Once the failing disk had been removed and a new one was installed, disk management certainly can assign any drive letter to that drive. One would need to be able to copy the EWA database from the failing disk (or another working PC), may or may not be possible.
Not important any more however as the issue was solved by a new installation.
Thanks given by: art_arev
1,725
Could someone send me a key for EPC 2018 with the database option "ctrl+F6" unlocked? I used two keygens, I checked these options and the code accepted but this option is still not available.
Mac : 28D2445A8B66
Fing32 Fing32
(05-12-2025, 04:20 AM)vadds Wrote: Could someone send me a key for EPC 2018 with the database option "ctrl+F6" unlocked? I used two keygens, I checked these options and the code accepted but this option is still not available.
Mac : 28D2445A8B66
xmcq82yuvd5try4ca3qehfzva4hfu5s
Thanks given by: vadds
1,727
Mac : 28D2445A8B66
UB5U8VGMQTYQ2QRKM6RFW4ESKU76QJ2
1,728
thank you
