(05-06-2019, 11:01 AM)miquu Wrote: Hello. I can do for you. Write to PM
i am currently repairing aw polo with crash data stored. So i am looking for flash files and found 2Q1909144M and 2Q1909144J seems to be in this thread, however where to find ZU and ZT ending files? It seems like vcp should be able to carry out this flashing procedure? Not that familiar with vcp so correct me if i am wrong. Flashing needs to be done with multiple files depending on what version is currently on module, is there any case that it could be done with just one file?
Thanks in advance,
Miquu
Polo 2018 AW reset steering assist P1609
46
05-09-2019, 11:48 PM
47
05-11-2019, 08:44 PM
[quote pid='1511405' dateline='1557122511']
Hi i have the same problem with ibiza 2018 power stering 2Q1909144F and fault 15788544 P160900 . I have already try odis , and odis online flash and parametrization SVM coding too and stil same fault no power stering , ane one can help ?
[/quote]
[/quote]
48
05-21-2019, 10:59 AM
Hi again,
i have finished flashing and coding succesfully and now i am having 3 fault codes left. Missing steering angle sensor and steering stop calibration but not able to do basic settings for them. Third code is about missing datasets and i think this causes problem with basic settings? Is this the case which requires online parametrization and is there way around this without odis? I am using VCP currently and have also licensed kts 2019 and vcds.
Thanks in advance,
Miquu
Thanks in advance,
Miquu
49
08-25-2019, 04:10 PM
Does anyone has a how to, how to fix this problem? I've read the thread but it is not very clear how to fix it? I've tried to contact multipe users who managed to reset the steering column but they do not reply. I'd be glad if someone could help me.
50
08-28-2019, 07:41 PM
(10-19-2018, 11:30 AM)hubson Wrote: Hello. I want to start the steering support after the accident. I've processed the odis. I made adjustments, parameterizations and settings for the kata sensor. The error disappears and then returns. I want to try vcds but I do not have a login. In the attachment autoscan.this in fact is a tricky one, neither odis nor elsa tells you the right procedure, the rack you have has to be flashed to the right equipment of your vehicle.
that's after you did the normal flashing and coding.
you need odis with online connection as you have to download a flash file. you have to go into odis right klick the steering cu then guided functions and then something like "parameterise" or so i can't remember what exactly it was.
ive had this issue 2 times now when non of the local audi dealers were able to do it and it ended up at our workshop.
some of them replaced the rack 2x and g85 as well without success. ( by the way g85 is not in the rack as stated here before i know that one of the test plans tells you so but its wrong !)
the testplan will ask you the pr number and what weight class your vehicle is then it will download a small file and flash the steering.
trust me i had exactly the same issue connect up odis right click steering rack cu and then guided functions. take a screenshot and send it here ill tel you what to klick.
happy to help any of you guys with same issue via Skype or WhatsApp just pm me...
i now you think you already flashed it etc.. but its an extra flash file that flashes a certain partition within the rack
Thanks given by: kiriakos1000 , mazaART , Serafimoff , plasticman1971 , Vag Coding , LUNA-trans
51
09-22-2019, 11:51 PM
Hello, if someone wants to, I also have the parameters for 2q1909144j for odisaE
Thanks given by: ncapuccio
52
09-24-2019, 02:13 PM
(09-22-2019, 11:51 PM)tomek112 Wrote: Hello, if someone wants to, I also have the parameters for 2q1909144j for odisaE
Hi, can you share this with us?
Thanks given by: krazen
53
09-27-2019, 12:34 AM
Hi
I need help I have that same. Problem
ecu number 2q1909144j
Iam looking flash
WBR
Iam looking flash
WBR
54
03-25-2020, 08:58 PM
I can write yes;
in my case nothing helped, the problem was not solved.
Ibiza 2018year, 2Q1909144J, reflash Odis Online, online parameterization, next reset to factory settings - no changes, sterring does not work, the error is still saved. I also tried to flash VCP, Odis engineered files;
- 2Q1909144J_6030_V001
- 2Q1909144ZU_BOOT_V001
- 2Q1909144ZX_BPLD_V001
- 2Q1909144ZX_BPLD_V002
and nothing. power steering, if it didn't work, it didn't work
some say that Odis Online is the way to go. how ??
I am asking for tips as needed - I will pay.
if I helped, please THANKS and REP
R1200GS LC ADV, GP1800 SVHO
Thanks given by: siwygimela
