  • 61 Vote(s) - 2.95 Average
Porsche Piwis - KTS 650
Hello Friends.
I want convert a KTS 650 to Piwis.
Could you tell me where I could buy a HDD version Piwis V34.
You can answer me by PM.
In advance, thank you to all
(10-30-2012, 10:39 PM)aligator Wrote: Hello Friends.
you can download piwis from here:
http://mhhauto.com/Thread-Porsche-PIWIS-...=Piwis+V34
and you can put it on any hard drive as is vm (virtual machine) but the kts i think that is need a modification to work with piwis,ask for this.
111
Scanmatik - Kess v3 - DaVinci
Thanks given by: aligator , vincano , Examiner , 153771739
you still need to change the contents of the flash 29f800 but I did it KTS 520
Thanks given by: ParisCY , aligator
(10-31-2012, 03:58 AM)yarek Wrote: you still need to change the contents of the flash 29f800 but I did it KTS 520
can you give me more info about this?how you did it?
thanks
111
Thanks given by: vincano
if you want to convert a KTS 650 into a PIWIS, you will need special Board. I have a original Porsche PIWIS Board that fits in KTS 650 and also works with SD Card. But I use V29. I have tried V32 but it changed the Bios.....
I can help you to convert the Piwis KTS 520, but only because I did and I have to everything you need.
If it can be converted KTS 650 as well as 520 is with a nice happy to help you
Check this my friend.
KtsFrwUpdt.rar
1,297
7.71 MB
Thanks for the FW update but can you give some info for the cable that is used .
I have the kts520 and want to be sure if the china cable will work or is needing modifications ?
I want to remap the ecu for a 955 2008 .I need something else ?
If I help you please push the [Image: postbit_thx.gif] and [Image: postbit_reputation.gif] buttons .
(11-08-2012, 08:18 AM)Freezzby Wrote: Thanks for the FW update but can you give some info for the cable that is used .
I think for remaping/tuning etc. you should use suitable hardware, but can be wrong.
03-25-2026, 08:17 PM
01-07-2026, 04:18 PM
