  • 14 Vote(s) - 2.64 Average
SD connect lan connection problem
It is not locked.
It has corrupted firmware inside.
  • SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
  • HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
Is there any way to force firmware update without toolkit?
A pic exchange with a correct dump?
Toolkit does not update PIC.
Sorry, i don't explained correctly.
My question is :
If I change PIC16LF88 with a correct dump I will be able to connect to C4 by lan cable?
http://mhhauto.com/Thread-SDConnect-unlo...g-solution
(10-20-2016, 01:11 AM)salbutamol Wrote: Sorry, i don't explained correctly.
My question is :
Firmware is not stored into that PIC. Flash memory will keep that stored.
You mean both flash memories 29f016 from this image (a, b in pencil)?
They are the same that contains SN.
This is Caesar flash. Application and boot use two different flash IC.
(10-20-2016, 02:22 PM)Anturage Wrote: This is Caesar flash. Application and boot use two different flash IC.
Ok thanks for the info.
Do you know exactly what Flash IC would have to change?
and you have this programmed IC to purchase as replacement?
I can supply any original part from SDConnect.
But i'm not sure the main problem was in Flash IC.
Could be dead RAM or some other fake component or bad soldering and bad power supply circuit cause data corruption.
