  • 13 Vote(s) - 2.54 Average
Support thread for FullFixbySamik paid version
181
(07-03-2025, 06:44 PM)Frenki1995 Wrote: Hi sweety!
Where can i update addons after xentry installation, before i activate your fix? I would like to dig around, but dont want to fck up the clean installation.
Thanks for the reply!
Okay i just yolo’d the setup and every software works fine on 06.2025. Thanks for your good work, keep it up!
- greetings from Hungary
(P.s.: everybody who is struggling with the setup, u should fix things on your side first, this is the easiest diag system activation i have ever done)
In addon centre
G'Day Sam,
I'm having trouble using the FULLFIXBYSAMIK V8.3.0 on a clean XPT 25.3.3 install. When attempting activation (during Monaco DTS 8.1.6 install), I get Error when starting the hardlock service (photo attached). Additionally, no activation of XPT occurs and it cannot be run, and no ZenZefi certificates are installed.
Hoping you may point me in the right direction.
(07-07-2025, 12:26 PM)noaahlou Wrote: G'Day Sam,
I'm having trouble using the FULLFIXBYSAMIK V8.3.0 on a clean XPU 25.3.3 install. When attempting activation (during Monaco DTS 8.1.6 install), I get Error when starting the hardlock service (photo attached). Additionally, no activation of XPU occurs and it cannot be run, and no ZenZefi certificates are installed.
From your screenshot, i can see that your system is not so good. Anyway, that error not with Monaco and not with activation, can just skip of there's no others.
Need clean system with Windows 10/11 Pro, original, not some light versions from some torrent website, not with tweaks or any shit!
You wrote no activation in XPU.
What you means?
XPT?
If in fix you checked Activation Xentry option, then maybe you forgot disable Secure boot from bios. Sure you didn't see such message?
Anyway, even if you disable it, just run fix one more time, with only activate Xentry option.
Hi
I had to reinstall Xentry 03/2025. I use Fix 8.3
After the reinstallation, offline login no longer works.
Regards Rudi
(07-08-2025, 08:06 PM)rudi2 Wrote: Hi
Regards Rudi
In new versions, need to enter login and password:
z
z
hi what is the pass for xentry Login ?
program not working
user :z
pass: z
not working
program not working
user :z
pass: z
not working
Run exactly Xentry! Not simulation, not Akt!
Run Xentry and input:
z
z
If didn't work, send Anydesk ID and password by PM.
Hi there Folks,
The installation went flawlessly for 0923.
I finished up loading the WIS ASRA package.
 WIS works beautifully.
One question, my pervious EWA link used to also contain EPC
I've searched through my install and can't find any reference to EPC.
I don't want to load a package that might mess up my perfect install !
Users browsing this thread: 5 Guest(s)
