  • 13 Vote(s) - 2.54 Average
Support thread for FullFixbySamik paid version
127
(05-01-2025, 03:49 PM)ClkCabrioDriver Wrote: Hello Samik!
I've bought your FullFix 8.2.3 and installed it on a fresh Win11 and fresh XDOS 12.2024. I've tryed to connect via Enet Cable to my EQB but it won't work.....plz take a look at my screenshot, perhaps you can give me a little help.....
Thank You!
EQB working with CAN, you can't connect to it with Enet cable.
Thanks given by: Rocinante , ClkCabrioDriver
128
Thank You!
Do you have any suggestions for an. Adapter?
Thank You!
Cheapest is Openport 2.0.
Better VCX SE.
Better SDConnect C4.
The best Xentry VCI.
Thanks given by: ClkCabrioDriver
130
Tried on Vediamo, DTS Monaco and Xentry i can't connect to any of them. Using V8.2.1 and Xentry 09/23
(05-08-2025, 07:08 PM)macbut999 Wrote: Tried on Vediamo, DTS Monaco and Xentry i can't connect to any of them. Using V8.2.1 and Xentry 09/23
You forgot write which adapter you are using, which version of Xentry you are installed.
And have question, why v8.2.1 if there's newer version?
Using C4 DOIP and XDOS 09/23. I will download and try with newer version
(05-08-2025, 08:07 PM)macbut999 Wrote: Using C4 DOIP and XDOS 09/23. I will download and try with newer version
Xentry OpenShell 09.2023 working with SDConnect in stock, so need to configure only IP address and check firewall.
Vediamo and Monaco you have to configure for SDConnect.
Something need to do yourself)
134
Before i start installing new windows and XDOS again, does FullFix Work on modified windows versions, like Tiny 10 or Tiny 11?
I just want lighter and bloat free windows Smile
(05-14-2025, 01:06 PM)olluska Wrote: Before i start installing new windows and XDOS again, does FullFix Work on modified windows versions, like Tiny 10 or Tiny 11?
I strip out the bloat after installation and have not had a problem but I guess it matters "what" is stripped out.
I would think that if Xentry installs, the fix should work.. all you can do it try it with the free version first..
Thanks given by: Sam!k
