(10-13-2024, 09:51 AM)NewDriver Wrote:(10-11-2024, 08:41 PM)Sam!k Wrote: When you install clean new Xentry, there's no Toolkit and doesn't matter did you run ConfigAssist or not.
After installing fix, you need run ConfigAssist and select SDConnect to switch SDConnect mode.
After that Toolkit will start automatically and even if you didn't write any IP address, Toolkit have to see SDConnect!
If didn't, it means you have some problem with ethernet adapter, lan cable or SDConnect.
My laptop Ethernet adapter is working fine. I tested with Router via LAN cable this morning. Please see attached photo.
My SDconnect is also working fine. I tested with another laptop.
Please tell me how to fix this SDConnect. Thanks in advance.
Fixed!
Firewall was blocking Toolkit.
