(04-04-2025, 01:48 AM)Alextn Wrote:(04-02-2025, 10:12 PM)Bogdan Beb Wrote: No power and black smoke..
Can be egr opened, flaps closed, exhaust back pressure too high( will force to increase egr rate)
Check also camshaft sprocket blade key
Has the engine overrevved in the past due to oil in the intake?
Checked EGR, also disconnected before starting to keep it closed and no change, flaps have been deleted previously by someone else, 6mbar of pressure on DPF at 3000rpm. I tried to scope the camshaft sensor but with no luck. I'm still trying to figure out this scope thing
(04-02-2025, 10:56 PM)chindasvinto Wrote:(04-02-2025, 02:28 AM)Alextn Wrote: THE ZAFIRA FROM HELL
2010 1.7 cdti
Replaced and checked the following from known good car:
Injectors, high pressure pump, fuel rail and sensor, turbo, EGR, EGR cooler, cat with sensors, dpf(someone drilled 2 holes) , checked timing, compression is 27 on all 4, replaced ecu, remap ecu with original file, checked all grounds to ecu with 21w bulb, MAF sensor, checked intake with smoke, checked vacuum hoses with smoke.
And still NO POWER and a LOT OF BLACK SMOKE.
I just got a handheld oscilloscope, what should I look at? Also if anyone could help me with some good known waveforms I would really appreciate it. Thank you guys.
This is my last hope to fix it. If not I'm going to scrap it.
no dtcs driving the car?
No fault codes unfortunately
(04-03-2025, 05:40 PM)wdariusw Wrote: Do smoke test. I think that you have air leak somewhere
I did, no leaks, not intake or vacuum
I think that car should have DTCs. Won't it have several DTCs off?
