Utility File 15816943 request.
Hello everyone, I'm hoping someone may have the listed utility file for DPS programming. If you do please consider sharing it, thank you.
(06-22-2025, 04:25 AM)Dezzz Wrote: Hello everyone, I'm hoping someone may have the listed utility file for DPS programming. If you do please consider sharing it, thank you.
It's not a utility file it is a calibration file.
Just don't want anyone confused as the utility file is never listed by DPS when doing a controller info get.
The top right hand side in DPS shows you the calibration numbers in order that the utility file that you have been given separately loads the files into the module.
Thanks given by: Dezzz
Thanks for clarifying this Zooper, makes a lot more sense now.
01-08-2026, 07:02 PM
