  • 24 Vote(s) - 2.79 Average
VPO -12 error?
Error when online coding VPO -12
Any ideas. Yudi is not available apparently533
Which version of star do you used.
7/2015 with vpo - 5 fix
Thanks given by: smartcard
You need the profi_cd.ini for a newer release, what is it PKW?
Here is the guts from my 05/2016..
[DEFAULT]
DAS-CD-NR=05/2016 (2016-03-16)
FlashData=2016.05.011
CAESAR-NR=03.01.99
MVCI-NR=08.02.026
Just transfer the file to the folder. And will work
Thanks given by: 93r1 , smartcard
Just the file in the PKW folder need modified? Will try that now...
Just change pkw? Or you have to make all the folders?
Profi_cd.ini
Just transfer it with replacement
Thanks given by: ToMiBoY
I have same mistake and tried to replace it and nothing happened...
Fixed it with your advice, in Smart folder
[Image: katalogs-logo-spin.gif]
