42
Thanks Given: 132
Thanks Received: 214 (115 Posts)
574
30
Which version of star do you used.
2,095
Thanks Given: 14574
Thanks Received: 17429 (4938 Posts)
6,536
46
You need the profi_cd.ini for a newer release, what is it PKW?
Here is the guts from my 05/2016..
[DEFAULT]
DAS-CD-NR=05/2016 (2016-03-16)
FlashData=2016.05.011
CAESAR-NR=03.01.99
MVCI-NR=08.02.026
______________________________________________________________________________________
42
Thanks Given: 132
574
30
Just transfer the file to the folder. And will work
Thanks Given: 179
Thanks Received: 112 (51 Posts)
189
28
Just the file in the PKW folder need modified? Will try that now...
Thanks Given: 49
Thanks Received: 3 (3 Posts)
15
Just change pkw? Or you have to make all the folders?
28
Thanks Given: 17
Thanks Received: 217 (110 Posts)
204
Profi_cd.ini
Just transfer it with replacement
40
Thanks Given: 345
Thanks Received: 270 (56 Posts)
424
14
08-22-2016, 02:52 PM
(This post was last modified: 08-22-2016, 02:56 PM by stealth.)
I have same mistake and tried to replace it and nothing happened...
Fixed it with your advice, in Smart folder
