110-06-2016, 12:07 PM (This post was last modified: 10-21-2016, 02:34 PM by McDj85.)
I did get a very cheap HVAC with REST, but my car is left hand drive and the climate controller is for a right hand drive.
I have been doing investigations, and the only difference between LHD and RHD is that the flap motors are in different order in the LIN loom. So what I think this means is that the flap motor ID are different between LHD and RHD.
So I have gotten couple possible ways to get this work.
1. There is some setting that could be changed from cbf to switch the device motor ID from my current LHD to the HVAC needed RHD ones.
2. There is an eeprom on the device that holds this information, would need like 4x of eeproms from LHD and 4x from RHD cars to find differences.
3. There is the possibility to manually set motor ID from Vediamo, maybe use this to set the correct ones for RHD HVAC.
4. Flash LHD cff, but I have looked ID tags of different devices and there are same HW and SW for device between LHD and RHD and even climate controller with and without REST. So I'm not entirely sure if this will help. My CFF files only seem to have USA flash files, and I would need ones for Canada Celsius ones.
Does anyone with more knowledge know which way this could be done?
210-14-2016, 02:19 PM (This post was last modified: 10-14-2016, 06:42 PM by McDj85.)
Ok, I have been doing more investigation.
I know that HAVAC's are not the device to make money, so the interest is much lower to explore these devices.
Well my new 3-zone, rest (581) HAVAC has
HW:2048301790
SW:2044422805
There is no update flash for hw 2048301790 made by merecdes, at least exploring few SDFLASH dvd's. This leads me to conclusion that the RHD and LHD is coded to the eeprom at the HAVAC. This HAVAC is from the first W204 line with the big side blinkers on the mirrors.
So I'm asking if someone with 581 HAVAC with same HW and SW and left hand drive could send their eeprom to me and I could upload it to my device and see if this will work.
To read the eeprom with USB Programmer CH341A that costs less than 5$ and a soc testing clip that clips straight to board without the need to solder anything.
Or if someone pro has some tool that can read the eeprom data trough obd2...
I attached my eeprom if someone else needs the RHD one.
Note that changed my vin to the orginal one and my system has error that initial startup has failed, and I think this information is also registered to the eeprom since it won't go away even after I boot the device. Can't run initial startup since I don't have all the motors on my car.
More info about the eeprom:
Device number: 2048309985
Q:03
HW:2207
KW:10/08
SW:2307:00
Device is Celsius based.
Diag ver: ECE_Kanada_3_Zonen_16
I did open my orginal HAVAC to try download that eeprom and try it but it doesn't have the eeprom chip that the older HVAC had.
And the NEC main processor flash thingy has been upgraded from 70F3236M2GCFG2/(A) to F3376AM2(A1)FG3. I think that the newer chip might have an eeprom inside it, but cant be sure since cant seem to be able to find a datasheet for this chip.
I have no idea how to even read this NEC chip and what tools would be needed. And I think it would need to be removed from the board and this just seems to risky to burn my original HAVAC.
So if anyone does have a ATMEL25320AN eeprom for Celsius and LHD version even if it was 580 I think this eeprom might be able to be used.
Doing some more investigation about the errors that I'm getting.
I do understand the errors with flap motors missing but then there are also the temperature sensors left and right that seem to be missing.
I think this has something to do with that the device is from a pre 2008 car and mine is late 2009, meaning I already have the sleek mirrors and the other one didn't.
Well there seems not to be never flash ware for this older device HW and the chips have changed so I do think this version of the 3-zone HAVAC is a mission impossible to get to work with my sensors.
I have not been able to find anything to suggest that the right hand drive and left hand drive was the problem. Which I first started to suspect... Mainly because I did get an error saying that one motor is there but the operation range was wrong == mechanical failure at motor.
I got a facelift HVAC with Air Flow button.
Now everything else seem to be working but air distribution to footwell.
I do assume this is because the air distribution motor is now with the new HVAC defrost vent flap right and not footwell flap left as I think it should be.
If someone has 3 zone climate control in their car could you read the actual motor values with vediamo?
Comands are:
DT Klappe Diffuse Duese lesen Aktuelle Motoradresse:
DT Klappe Entfrostung links lesen Aktuelle Motoradresse: 24
DT Klappe Entfrostung rechts lesen Aktuelle Motoradresse: 25
DT Klappe Fondtemperatur lesen Aktuelle Motoradresse:
DT Klappe Frischluft Umluft lesen Aktuelle Motoradresse: 22
DT Klappe Fussraum links lesen Aktuelle Motoradresse:
DT Klappe Fussraum rechts lesen Aktuelle Motoradresse:
DT Klappe Mittelduese links lesen Aktuelle Motoradresse:
DT Klappe Mittelduese rechts lesen Aktuelle Motoradresse:
DT Klappe Stauluft lesen Aktuelle Motoradresse:
DT Klappe Temperatur links lesen Aktuelle Motoradresse: 2A
DT Klappe Temperatur rechts lesen Aktuelle Motoradresse: 2B
I'm most interested about Fussraum links, if you could also read it's:
DT Klappe Fussraum links lesen Direction:
DT Klappe Fussraum links lesen Safety:
DT Klappe Fussraum links lesen Safety enabled:
These are needed for programming, I will post the ones I know when I get the list.
I doubt you will get any help with your problem here. Why not simply buy the correct unit for your lefty? This seems like using a sledge-hammer to open a nut.
You might be right... Just hoping that some here might be as interested on exploring the cars inner workings as I am, and willing to share...
The quest here is to fit 3zone control unit to a car that has 2zone systems. This is mostly to get the rest feature, since there already is a circulation pump.
So there are no right version that would works straight =o)
(11-12-2016, 09:40 PM)McDj85 Wrote: You might be right... Just hoping that some here might be as interested on exploring the cars inner workings as I am, and willing to share...
Of course it's possible. I saw people convert 2-zone into 4-zone before. It all depends on willingness, work, money and most importantly, is it worth the hassle?
